Question about Janome Memory Craft 10000
How do i open the side door on my janome 1018s where the neddles and light is
  • Janome Master
  • 7,365 Answers
On some sewing machine the door is called Lamp Cover Door & has a hinge at the back of the door,, gently pull toward the back of the machine to open the door & the light bulb should be easy to get to.
Some are called Face Plate-there should be a plug in the middle of the door-remove gently with a small screw driver- there should be a small screw to remove-the door should come off easily--change bulb--replace screw-replace plug
Posted on Oct 07, 2010
What kind neddle do i need for a New Home sewing machine Model HF 106
Janome sewing machine needles should work on your machine
http://www.sewingpartsonline.com/janome-hf106-sewing-machine-parts.aspx
or
just try good quality brand needles with this code: 130/705H
Jul 03, 2017 | New Home Sewing Machines
I have a Janome JF 1018s. It does not feed fabric. I have done a basic maintenence but that has not helped. How can I fix this problem.
not feed fabric Leigh Anne, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sewing Machine Not Feeding Fabric
https://dealers.elna-usa.com/Documents/Janome%20Service%20Manuals/SM%20JF1018S.pdf
Why Is My Sewing Machine Not Sewing or Feeding Fabric
Jul 26, 2016 | Janome Sewing Machines
Neddles to suit janome mylock 134.
The needles required will be listed in your manual, if you don't have a manual then buy any needles recommended for sergers/overlockers. Or check on the Janome website.
Nov 23, 2013 | Janome MyLock 634D Mechanical Sewing...
Janome 7025 have mislaid manual and can't open side of machine to replace bulb, have removed screws but it won't come off.
After removing 1 or 2 screws on the side cover, that side cover should come off with a good tug. Janome also puts tabs on the side cover to help hold it on, and they do stick sometimes. If you can get your whole hand over the entire cover, get a good grip on it, and just give it firm yank.
Apr 27, 2011 | Janome Sewing Machines
Putting the neddle in which way does the flat side go
flat side goes to the back of the machine
Dec 06, 2010 | Janome Harmony 2041
I have a Janome 5700, the light has burnt out and there is no directions in manual for changing it, I also cannot find the burnt out light. Can you help. Thanks Penny
Most sewing machine lamps are located inside the face cover on the left hand side of your machine. It should pull open as it is hinged at the back and clicks into place when you close it. The lamp will be visible to you when you open your machine. It will either need a bayonet or screw type bulb replacement. You will need to look at the broken bulb in order to see what type your machine needs.
http://www.janome.com/documents/File/ManualFile/MC5200.pdf
If you look at page 4 of this manual, which is similar to your machine, you will see the face cover is part number 11. In the smaller picture below you can make out the hinge on the back of the machine that allows you to open the face cover like a door. Hope this helps!
Sep 03, 2010 | Janome Memory Craft 5700
Model janome year 1996, model 1018....how do u open the side part where the needles is and the light....its should just swing open...shouldnt it ???
The white button on the side of the door comes off and there is a screw there that you will need to undo and vola
May 03, 2010 | Janome Memory Craft 10000
LED screen won't light up on New home 8000
First, open the lid where the feet are stored, look on the right side front of the backside of the panel for a round knob. This is the brightness control. Turn it gor more or less brightness. If this doesn't solve the problem, you have a bad screen which must be rebuilt by Janome . Take the machine to a Janome dealer (they are the only one's Janome will deal with) who wilremove the panel, send it to Janome for a rebuild and reinstall it for you. You may as well have the machine serviced while this is being done as everything is already exposed for proper cleaning and lubrication. Be aware , this may cost as much as $400 but the machine is worth it.
sewman7
Jan 11, 2009 | Singer 2662
Janome 6500
Under the cover of your machine where the feet are stored, on the right side,front of your machine is a round button which controls the brightness of your display. It was probably moved during cleaning.
sewman7
Aug 09, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
189 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
