Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2007 Harley Fatboy Taillight problem.
The tail light on my 2007 Harley Fatboy stopped working tonight. However, the brake light works fine, it comes on whenever the brakes are applied but then the light goes dark when released.
Is the normal light on a different wiring or fuse than the brake lights?
  • 1 more comment
  • markc573 Jul 31, 2008
    Same problem as listed. All of a sudden the tail light stopped working, but the break light is fine. I haven't checked the bulb, so I'll do that first.
  • wood808 Mar 15, 2009
    I have an 08 fatboy that kepps blowing the running light but not the brake light. I have changed to bulb 4 time. can aonyone help
  • Anonymous Mar 23, 2014
    I can smell fuel after parking it. its a 2007 fatboy with 11,900 miles
Check to make sure BOTH light filaments are intact. Or try another bulb to double check the situation before wasting to much time on a simple fix.
Posted on May 30, 2008
My Harley 2005 fatboy brake light and signals stopped working checked the fuses could it be the ignition switch
Hi, Anonymous the brake light could be a faulty tail light bulb or brake light switch or a wiring issue, the turn signals could be a turn signal module or rear fender tail light wiring harness connector or damaged harness under the fender from the rear wheel rubbing for this scenario you will need a service/owners manual that has a wiring diagram if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
https://serviceinfo.harley-davidson.com/sip/index
Instant Tech Relief
Jul 19, 2016 | Harley Davidson FLSTF Fat boy Motorcycles
My headlight and taillight dont work but my taillight will come on when i apply the back break. how can i fix this problem
Check you lighting fuse first then if it is good separate the two problems and identify if the brake light is what is coming on or the tail lite or both elements. When that is corrected move on to the headlight.
May 20, 2014 | Harley Davidson XL Sportster 883...
2010 Harley Davidson FLSTF Softail Fat Boy tail light not working
Hi, Laynebk tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Tail lights and brake light issues
http://proudfewmc.net/SiteAssets/99483-11.pdf service manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2010-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Oct 24, 2012 | 2010 Harley Davidson FLSTF Softail Fat Boy
Tail light and foot pedal brake light does not work but hand lever brake light works.
Probably a bulb/ rear brake switch combination. If your front brake switch is working, then half of the bulb is working. No taillight issue, probably a bulb. No rear brake light, probably the rear brake switch. Located on the lower right rear of the frame, behind the exhaust. Check for power on the orange/white wire at switch. If you have that then check for power on the other terminal of the switch while pushing on the pedal. The rear brake switch is hydraulically operated so you must have adequate pressure to activate it.
May 04, 2012 | Harley Davidson Harley-Davidson Motorcycle...
2001 Wrangler brake light not working correctly. Tail light works, brake light uses only one bulb filament. When boht tail light and brake light are engaged neither filament comes on. Passanger side...
The light assembly is grounded to the body through the mounting screws. It sounds as though it is a bad ground. You could run a ground wire to a bolt on the frame from a mounting screw to check for aground problem.
Mar 19, 2011 | Jeep Wrangler Cars & Trucks
Problem with the signal lights on my 2002 Harley Fatboy
Can you check if the bulb is busted? Most likely your tail light bulb is fused.
May 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Installed new led taillight and now there is no brake light/blowi
I fixed it. The LED light needs a "load equalizer" to operate properly. Instructions said nothing of needing one. I combed the internet and found the answer. I responded to FixYa by e-mail "REPLY" and informed of the fix. Thanks for your help...I'll remember your site for future needs.
Mar 19, 2009 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Lands Phones Logo
451 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
