Question about Nokia N70 Cellular Phone
How many hours we should charge the battery fist time Nokia-2700
  • 2,574 Answers
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Posted on Oct 07, 2010
How to switch on nokia 2700, battery is nice then also not getting on
simply keep it for charging.. the battery must be down . it doesnt start if battery is down.
Jun 07, 2012 | Nokia Classic 2700 Cell Phone
Nokia 2700c battery low problem
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Nokia Classic 2700 Cell Phone
Forget my security code for my nokia 2700
Hello Djds,
Switch off the Nokia classic 2700 phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia classic 2700 phone.Enter the default code 12345 or 00000. Your Nokia classic 2700 phone will be unlocked.
Sep 20, 2011 | Nokia Classic 2700 Cell Phone
Nokia 2700 betri low prolem
Low battery problem? Simply buy a new Nokia Battery and your phone is as good as new.
Thanks
Sep 17, 2011 | Nokia Classic 2700 Cell Phone
How to solve battery charge draining problem for nokia 2700 classic
First thing to check is the battery,if you can try and test another one,you can conclude weather the phone or the battery is the problem,also try to check the charger you are using,might the current is not sufficient giving the battery a charge.
If this 2 methods does not work and still give you a headache, bring the phone to a mobile service shop to diagnose the phone problem,might need to change some components such us charging IC,capacitors or resistors.
Sep 15, 2011 | Nokia Classic 2700 Cell Phone
Nokia 2700 classic i want to open security code
Hello Dilip,
Switch off the Nokia Classic 2700 Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia Classic 2700 Phone. Enter the default code 12345 or 00000. Your Nokia Classic 2700 Phone will be unlocked.
Jun 14, 2011 | Nokia Classic 2700 Cell Phone
Nokia 2700 c charging not supported
Possible failure of the Charger unit. If the capacitor within the charger has failed this can happen. So try to use another charger to confirm. If so replace or you will need to cut open the charger to replace the regulator or the storage capacitor.
make sure that the battery also is good try it on another set to confirm as a bad battery also will show no charging display.
Jan 18, 2011 | Nokia Classic 2700 Cell Phone
Low battery back up
1 reples batter
2 chaging 2 h only batter
3 heeting M/B
Dec 25, 2010 | Nokia Classic 2700 Cell Phone
What is the initial battery charging for nokia 2700 classic?
normaly 16 hours then no more than 90 mins or you will decrease your battery life.
regards Tim
Dec 14, 2010 | Nokia Cell Phones
Battery runs down within a hour after giving an outgoing call.
this is a hardware problem form chip called "thavo" should be replaced
Apr 18, 2010 | Nokia 6630 Cellular Phone
Nokia N70 Cellular Phone Logo
354 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
