Question about Canon PowerShot A620 Digital Camera
Power not working
No power, i changed batteries---what else?
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Note as per these tips that there's a silver rectangular switch on your SD card door, and a black switch on your battery door. Inspect both of these to make sure they are being activated when the doors are closed.
Posted on Jun 04, 2008
I have a Dell E6400. I know, ancient! Is it normal that it gets slower when charging? Like when it's using battery power, it's noticeably faster, but when I plug the charger in it just gets slower..
1.Install the system again. If it works, over!
2.remove the battery, and turn on your notebook with charger. If it works, there may be
something wrong with your battery. You can change a new battery.
3.Install the battery,and plug the charger, power your notebook. Open the Power
management, change the Power plan to High performance.
4400mAh 6 cells Dell Latitude E6400 XFR Battery Replacement Notebook... 90W Dell Latitude E6400 Charger Power Cord Replacement AC Adapter Latitude...
Jan 12, 2017 | Dell Computers & Internet
Samsung 145
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Jan 15, 2014 | Samsung N145-JP01US Netbook
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
Battery not charging samsung nc10- was OK the other day now just intermittent blue flash when plugged in. unplug and no power. removed battery and charger works. Fn F2 00% battery life!!- do you think a...
try holding the power button for 30 secs with the battery out and unit powered off it allows a static discharge and might help its what my wifes g60 requires from time to time good luck and hope this helps you out some
Mar 22, 2011 | Samsung NC10-14GW Notebook
My dog chewed my power cord. Dh "spliced" and taped for now. The laptop will work with power cord, but battery will not hold ANY sort of charge. Is the problem my cord or the battery now?
ask the dog.....!!!
ok sorry jokes apart...
was the battery working before ur dog helped u out...
remove the power cord and check how long ur battery can hold on till it dies down...when ur notbook is ON
if it holds for more than 10 mins then the battery will charge if the power cord gives it enough power to charge, else u may have a power adaptor that gives enough for notebook to work but not enough for the battery to charge at the same time....
u may have to change both the adaptor and battery....or else change the dog...ha ha ha...
u r the best judge....ask the dog to do some work on it may be......
just kidding....
Dec 14, 2009 | Dell Latitude D600 Notebook
Toshiba m105 s3021 battery problem
change the battery, and make sure your dc connector is no damange.. or changre the battery.. if now charging fix the chips for charging you can change it..
Sep 10, 2009 | Computers & Internet
Camera will not power on
Are you making sure that you are using Alkaline batteries? Regular batteries won't work. Even rechargables will only work if you first put in alkalines and change the battery type in the menu, then put in the NiMH batteries (not NiCads).
Mar 22, 2008 | Samsung Digimax S730 Digital Camera
Brand new batteries and its tellin me to change them!
please check if the batteries u used before have leaked any oil inside the camera. this damages the metal strip that shorts and two batteries. if there is no damage then tat portion s safe.
the small battery inside battery compartment is for camera date. dont disturb it.
after changing new batteries tha camera works for few time and then shuts down means your camera CCD s consuming lot of power. use a camera adapter to confirm that the camera works in normal power atleast.
even after this. camera shuts off itself. take it to service centre soon.
Nov 25, 2007 | Canon PowerShot A520 Digital Camera
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
Canon PowerShot A620 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
