Power supply problem
I have a 42plasma with a bad power supply. Screen was just black when I turn it on, so I was advised to get another power supply. I did and just swapped them out and now I am getting a real dim picture.
  • 5,568 Answers
Power supplies, while one of the most unreliable Asian electronic assemblies, generally are OK when new,
The previous supply may well have failed because of a more serious internal problem, likely related to the high voltage supply plasmas need.
Your new supply may fail very soon if this is the case and you will need a hands-on tech to diagnose the problem.
Posted on May 29, 2008
Backlight Inverter Repalced still not working
dim the lights in the room, turn on the set, and shine a bright flash light on the screen. Do you see a faint picture? Also be advised that there are a lot of bad parts floating around on EBay. No backlight condition could be cause by a bad main board, power supply, inverter board, high voltage short on the inverter output, or a bad backlight bulb.
Nov 07, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Have a vizio 42plasma about 4yrs old. a lil bit ago i started to get red an green flashes thru the pic then the other day i herd a pop an the screen went black. when i turn it on now the pic/image comes...
The main tv Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 26, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
Screen flickers lighter to brighter and then black screen. Does not reboot. Have reloaded everything and restored register.
Sounds like a bad LCD Power Supply... once warm is shut off... I'm not qualified to fix or advise... but this should point you in the right direction...
Dec 31, 2009 | Intel Motherboard
I have a Vizio VX32L and when I turn it on the screen flashes and goes black. The power light comes on and the vizio sign lights up and turns white. But the screen flashes real fast and goes black again.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX32L+
Please post back what you find.
Dec 16, 2009 | Vizio VX32L Television
ProView PA40JK1A screen just went black one day.
No, There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Nov 17, 2009 | Proview PA40JK1A 40 in. LCD Television
Monitor comes on momentarilly, then screen turns black. when power is turned off and back on again, screen comes on for a second, then goes black again. Is this a bad monitor?
The only problem that causes the power on and off is a bad power supply. Go onto http://www.ebay.com and search for the monitor (power supply). My dad's old LCD screen had a bad power supply, but I found my old printer power cable (HP PSC 750 All-in-One Printer), and the monitor turned on successfully. It's not a bad monitor, unless the PSU hookup is like the PC ATX/Baby-AT PSU cable, then it might be the issue. Monitors before 2004 or 2005 have the ones, like the HP PSC 750 uses. The monitor is either defective, or the power supply is dead.
p.s.: check the voltage, amp usage, etc. on the PSU for the monitor for better results.
Aug 28, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Sound only with a black screen.
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in if you have a soldering iron
Jul 26, 2009 | Samsung PPM42M8HB Plasma TV
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
