Question about ASUS P4P800S-X Motherboard
After starting the My computer fan is stop within a few seconds, S.M.P.S. is Working with good condition on other computer. The Power light of Mother Board is On
  • ASUS Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? while your at it
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no MOISTURE in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
hope this helps
Posted on Oct 07, 2010
I have an Intel E210882 mother board. Within a week, it was starting to become hard to boot, then I had to boot in F8 mode, and now when I turn on the power switch, the LEDs light turn on and the cpu fan...
If you have another computer that will hook up to the internet, download a copy of any live Linux CD (UBUNTU) and see if the computer will boot with that (you download a image file that burns to a boot able cd). If it will boot with a live CD, then you have a Hard drive / operating system problem. If it will not boot from that, you have a mother board problem. Start removing things from the motherboard, unplug and remove everything then plug hook up things one at a time.
Sep 18, 2010 | Intel Motherboard
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
Power On, Fans start but stop in few seconds and that's all
May be there is a problem in the windows, but suppose it is not booting at all.
First Check once more your boot options from bios menu
Second If it still the same thing, extract your battery out of your laptop for 12 min, then try to power up your laptop pluging in your power cable(don't use your battery)
Third If it still not working, there must be a problem in your cooling fan, so check it, also check your motherboard & your graphics card (Most of this problems happens due to a problem in the computer cooling system in motherboard & graphics card)
Hope it works for you Christos
Jan 30, 2010 | Toshiba Satellite P200-0TD00Y Notebook
I have HP 305W. When turns on the power, it stops within 5 scnds
sounds like your motherboard lost a control chip. that makes the power supply cycle off, when m/b doesn't send correct signals to continue boot.
Nov 27, 2009 | HP Computers & Internet
The purple light is flashing in the front and tries to start and won't turn on. disconnected power cord and held button in for thirty seconds still have same issue what could it be?
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Jun 21, 2009 | E-Machines T6216 (827103077834) PC Desktop
Computer does not boot
If you computer over heated, this could have caused the board or power supply to short. I would first start by trying a new power supply unit (since this is cheapest of the options). If that does not work then try replacing the motherboard and/or processor. Since you not getting any power, my guess is motherboard or power supply unit.
Apr 20, 2009 | Intel Desktop Board D845PEBT2 Motherboard
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Hp nx7010 not starting
hi
it is mother board problem replace it it will help full to you.
by by.
Nov 18, 2007 | Compaq Presario 700 470024-192 Notebook
ASUS P4P800S-X Motherboard Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
