Question about Lgic Release LG KU380 3G Slider Phone
How to fix a lg380 that sometimes doesnt read my sim card, and suddenly turns every time i slide the slider down. ???
Phone was working fine and then all of a sudden the sim card slot stopped reading my sim card.
Samsung Galaxy Mega 6.3: SIM card not working:
Hello. sometimes the SIM card slot gets loose over time.
If you notice that it is easy for the SIM card to slip in and out of the card holder.. or if not you can try this fix anyway to see if it helps:
You'll need some scissors and some clear tape like scotch tape..
cut off a very small piece of tape just enough to cover the top part of your SIM card..
it doesn't have to cover the whole top part..
It can not cover any connectors..
after affixing, slide the SIM card back into it's holder to see if that works..
If that doesn't help, you may have to visit your local Service Provider's store to get a new SIM card
http://forums.androidcentral.com/verizon-droid-dna/276699-sim-card-improvement-maybe-not.html
Feb 11, 2016 | Samsung Galaxy Mega 6.3 Mobile Phone
MY NOKIA C2220 SLIDER PHONE SAYS ENTER RESTRICTION CODE WHEN I TURN IT ON ANYONE KNOW THE RESTRICTION CODE IT HAD A ROGERS SIM CARD BEFORE AND INM TRYING TO USE A SASKTEL ONE NOW
You can get the restriction code for your Nokia 2220 Slide ( C2220 slide ) from TheUnlockSpot.com by selecting the country & network to which your phone is locked and then provide the IMEI ( press *#06# to know ) when it is asked and get the unlock code through mail.
After you receive the code follow the method below,
1 - Switch on your Nokia 2220 Slide without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2220 Slide.
3 - Compose #pw+CODE+7#.
4 - The Nokia 2220 Slide would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly.
The letter w appears if you press the button star(*) four times quickly.
The symbol + appears if you press the button star(*) two times quickly.
Mar 10, 2013 | Cell Phones
I am getting a "No SIM card Installed" message -
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 30, 2010 | Apple iPhone Smartphone
At first I took it to some shop to upgrade the iPhone them I found out they either took my motherboard or sometime from the .... Phone.... Because I took it to another shop and that person they must of...
Reset
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 23, 2010 | Apple iPhone Smartphone
SD card doesnt have a lock toggle, but says protected and wont let me take pictures from my fugi film camera...why?
All SD cards should have a toggle, unless it has fallen out, or its one of the "specials" usually found in Sat-Navs which were made to be read only (with maps on). You don't say which Fuji you have - some used to take xD cards, which don't have a slider, but are easily recognisable by their one curved side of the card. I'll assume you have an SD card for this reply.
Here's a recap of what you are looking for:
On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked.
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to turn the camera off, remove the card, move the slider to locked, then back to unlocked. Replace in the camera and turn on.
As to your choices if it is broken (or a read only map SD card), then you might like to try the camera with another SD card, to see if the problem persists? (A reputable photo store will often lend you a card for the 20 seconds it takes to do this test)
Repair is very fidgety (even assuming you can find the slider). Most people tend to migrate their stuff to a new card.
Hope this is helpful.
Mar 05, 2010 | Cameras
Memory card is locked. Where is the lock?
This is usually caused by the SD card, and is nothing to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
Mar 02, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
WHY RIGHT PROTECT SHOW IN THE SCREEN
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked. (Sometimes it looks unlocked, but its so tiny, its actually in-beteen the settings. To make sure, slide it to locked, then back to unlocked again).
Have you tried the camera with another SD card, to see if the problem persists?
Feb 27, 2010 | Olympus FE-210 Digital Camera
When I try inserting memory card into Canon 890IS camera, I get "Card Locked!!" error message
Feb 25, 2010 | Canon PowerShot SD890 IS / IXUS 970 IS...
Apple icon is all that comes up.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Aug 12, 2009 | Apple iPhone Smartphone
Memory card does not lock into place for Sony Ericsson W910i
Some of the Sony Ericson phones have a little slider that slides back over the SIM card. This slider takes a bit of force, but be careful. Hold down the SIM and slide the retainer over the edge if the SIM.
Aug 10, 2009 | Cell Phones
Lgic Release LG KU380 3G Slider Phone  Logo
83 people viewed this question
Top Lgic Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Lgic Cell Phone Expert? Answer questions, earn points and help others
