Question about MSI PM8M-V Motherboard
PM8M3-V I installed a new gig stick of ram, now my pc wont start. It turns on, but does not boot, or start the monitor
  • Krickit222 May 29, 2008
    yes, both sticks reseated, 1gig 333, 512 333
  • Eric Smale
    Eric Smale May 11, 2010
    Please tell me your memory type that you are installing in the motherboard. Please be specific and detailed. This will help me try to sort out your problem. Also, have you removed the memory module are reseated it?
    Scholar:
  • 143 Answers
Perhaps the RAM does not like to coexist. I assume they are from different manufacturers. As mentioned already, try the modules by themselves to rule out faulty RAM or incompatibility.
Posted on May 29, 2008
    Scholar:
  • 187 Answers
Have you checked with one module at a time to rule out faulty RAM?
Upgrade BIOS to see if it will resolve hardware issue with new stick of RAM
Hi Szusza,
The new RAM module you purchased may be faulty, it is definitely possible that either due to a fault of the new RAM or on the slot you are trying to install it to cause the computer to not fully boot.
Have you tried to boot the computer with the new module only?
If not please try this:
Replace the original RAM module with the new one (make sure you insert the new RAM in the same slot you took the old one out)
If the PC boots you know the new RAM is fine.
If this does not work I would suggest getting your new RAM tested.
If it does work, put the original RAM back in the computer (in a new slot) if it does not boot after that then, there is possibly a problem with the RAM slot on the motherboard.
Dec 16, 2013 | HEWLETT-PACKARD Compaq Presario CQ5302F...
I had an intel d865 perl motherboard with a 2.8 processor and 4 gigs of ram, computeer ran great for years then one day i shorted the motehrboard and fried it, i ordered a brand new one and installed it...
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today.
If you are using the same motherboard as the first one, what you are experiencing is too weird to worry over. Is it still under warranty? I'd say you have proved that the MB is deffective. Take it back for a refund or exchange.
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today.
Jan 19, 2011 | Intel D865PERL Motherboard
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Upgraded ram to 2 gig from 4 X 256k
what system or motherboard you have ?
possible it don't support 2gig ram
try 1 stick of ram
Apr 10, 2009 | Computers & Internet
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Mar 25, 2009 | Microsoft Windows XP Professional x64...
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Added new ram stick now monitor does not recognise pc tower
According to this page (a memory vendor which I'm using only for illustrative purposes) your machine only supports up to 1gb sticks of the 400mhz variety. So you would use 4 x 1gb for a total of 4gb max.
Feb 21, 2009 | E-Machines T6528 PC Desktop
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
MSI PM8M-V Motherboard Logo
156 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
