Question about Sennheiser Professional Microphone
I'm looking for micro switch: SH ES-T 0.4 VA MAX, for mic sennheiser freeport wireless. Alex
    Prodigy:
    An expert who has answered 500 questions.
  • Sennheiser Expert
  • 611 Answers
Try calling Sennheiser to see if they have the part.
Posted on Feb 14, 2011
What if I use a freeport with the peavey 14 mixer
No what I will recommend to use one of the "Line" inputs as the level is normally at 0Db and then you will have control over it
Jun 11, 2014 | Sennheiser freePORT Wireless Instrument...
Senheiser freeport no sound
If it seems as though the transmitter signal is being received but there is no audio, disconnect the 3 or 4 pin connector of the mic and touch the different pins while transmitting to the receiver. If there is audio hum or buzz, the mic itself is probably dead. A wire could be off inside its connector.
Mar 04, 2014 | Sennheiser Audio Players & Recorders
Re Sennheiser presentation set Model No 21101 - I have no power to my receiver. The unit is plugged in to the mains and the socket is live as I have checked it by plugging in a table lamp which works fine....
The AC to DC "wall-wart" power supply is defective. Take the original to Radio Shack and have them sell you a replacement. No, RS isn't probably the quality of the original Sennheiser, but it will get you through your gig. PLEASE note the polarity of the tip-to-sleeve and match it up identical to the original power supply.
Sep 10, 2013 | Sennheiser freePORT Wireless Presentation...
How should I connect an ATM73a headset to a sennheiser SK300
Audio Technica and Sennheiser each have proprietary connectors for their mics. A lot of times the mics require Phantom power which is drawn from the battery of the pack.This is important as the mic will need to be wired correctly to function.
The first thing you will need is the correct plug from the company. Check with Sennheiser customer Support for the correct part. If you aren't extremely good at soldering, do not attempt this. You can change the plug but the wires are extremely delicate and can short easily. Moreover because of the phantom power, the plug must be wired correctly for the mic to function, or you may end up damaging the mic by sending phantom power up the wrong line. I would advise having a music store or pro audio service that handles these products do the wiring for you. If you feel you are up to it, you can do it yourself, but be careful.
Feb 19, 2011 | Sennheiser SK 300 G2 Wireless Bodypack...
Mini jack (3.5 mm) wiring schema. Thanks
Call Sennheiser. They have the wiring for their products.
Sep 18, 2010 | Sennheiser freePORT Wireless Instrument...
Bodypack sends no signal, turn switch from inst to
It sounds like the solder joints on the circuit board in the body pack are starting to fail or the switch is starting to fail. If you don't want to fix this yourself or it is still under warranty you might be better off taking it back to the dealer to have it replaced or repaired.
Nov 30, 2009 | Sennheiser freePORT Wireless Instrument...
On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
Sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Mar 02, 2009 | Sennheiser E835 Professional Microphone
Broken power switch
If you have a G1 SKM100 mic, the small on/off switch is an SKQLLC Tact switch made by ALPS. I don't know what's in a G2 or anything about the ones with the orange button. I just replaced the on/off switch and it took about 20mins. It's a bit fiddly but not too bad so long as you have a reasonably fine-tipped soldering iron. If you're in the USA then it look like there are a number of distributors who will sell one-offs. I'm in the UK and had to go back to the place I originally bought the mic from (DM music), who got it from Sennheiser and then sold it to me. For some reason Sennheiser wouldn't sell it to me direct. Good luck.
John
Dec 14, 2007 | Sennheiser SKM100 Wireless Handheld...
Sennheiser Professional Microphone Logo
216 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
