Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Getting f1 flashing light and a picture of a wrench. how do i turn it off
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
Flashes F1 and a wrench symbol... water doesn't drain
Assuming you are getting the F1 error in both drawers.
This means there is water at the base of the housing under the bottom drawer.
Turn power off and take the drawer out. You will have to pull out the plastic pins on either side and get the front cover off. This will enable you to pull the drawer out from the slide bar for better access. Use towels and hair dryer to get rid of all the water. The flood switch is mounted on the power board. Use hair dryer to dry this out.
Put everthing back and turn power on.
Post a comment if this is not fixed or the F1 is only coming in one of the drawers.
Please rate this solution.
Sep 01, 2010 | Fisher and Paykel 23 in. DD603H SS...
Showing f1 and a wrench picture shows up
The flood switch at the base of the dishwasher (under the drawer) has triggered.
You will need to turn the power off (at mains) and extend the drawer as much out as possible. Use towels to dry the base and if possible use a hair dryer.
Turn power back on and try.
Possible causes are kink in drain hose (or crack), foaming detergent (use recommended powder).
Please rate this solution if satisfied otherwise post a comment.
May 19, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 display flashing?
Flashing wrench means a fault code has been triggered.
F1 is the fault code when flood switch at base of dishwasher cabinet turns on.
This can occur due to several reasons when moisture gets to the base of the drawer cabinet.
You will have to turn the power off and extend the drawer out as much as possible to expose the back of the cabinet. Take towels and a hair dryer to dry the base. Once the flood switch gets dry the problem will go away.
The main thing is why did the water get there. You could have a crack in the hose or simply the detergent may have caused too much foam.
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Cant turn off the dishwasher
Babas, the F1 fault code for most FP dishwasher models means that there is a leak. It can be one or both drawers. Regardless of which is leaking, your fault code is telling you that the base pan has water inside. You will probably need to call for factory service to repair.
Mar 31, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 light flashing with a picture of a wrench
See http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm, or http://www.fixya.com/support/t103415-fisher_paykel_dd_603_dish_drawer
Aug 24, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
127 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
