Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
I have a GLTF2940ES3 front loader. It is a bit over a year old. Today we went to take the clothes out and they were soaked. We tried running drain/spin, rinse/spin...nothing. It does everything except the high speed spin. Water drains fine..."whirring" noise when it should be spinning....we tried lessening the load too, and nothing. Please help!?!?!?
  • 14 more comments
  • dacheesewhiz Aug 05, 2008
    My frigidaire front load washer GLTF2940ES3 doesn't spin in high speed. It goes through the tumble action but no high speed spin. It is exactly 1 1/2 years old. the pump pumps out water though. I put the machine on drain/spin setting wich is about 13 minutes. It seems to count down to 9 minutes remaining rather fast, while draining/pumping only. At 9 min remaining, it then begins to rotate back and forth about 6 times (i think to balance the load). At 7 minutes remaining it just beeps once and shuts off. I never get the high speed spin. On the other cycles, everything seems to work but the high speed spin cycle. Any help would be much appreciated. Thank you in advance
  • ACEPAINT Aug 15, 2008
    WASHER WILL NOT SPIN. DOES EVERYTHING ELSE BUT SPIN. REPAIR MAN SAYS ITS THE CONTROL BOARD. BEEN WAITING 2 1/2 MONTHS FOR MY PART. ANY OTHER THOUGHTS. HELP JAZZIE
  • dachshundluv Aug 16, 2008
    My Frigidaire front loader stopped spinning 2 months ago. Repair tech replaced PCB main and motor control...no luck. Then he replaced the motor..no luck. Next he thinks that the PCB was bad and ordered another one. Finally, Lowes called me with good and bad news. The good news is that they are refunding me the purchase price + tax. The bad news it is on a Lowes gift card. I truly hate this machine. The clothes were always smelly and I had to manually siphon water out of the door gasket. Is there anything else I can do, other than advise others not to buy this model ?
  • arektrzep Aug 26, 2008
    washing mashine stains laundry
  • Anonymous Aug 28, 2008
    I just bought my washing machine and it wont spin. I have not used it even once. This is very frustrating. All of my clothes were soaking wet. I tried varied load sizes with no success. I also tried the spin only cycle and the drum just rolled back and forth and shut off after two minutes.
  • alisa10 Aug 30, 2008
    our washer is about a year and a half old and it has just stopped spinning. The clothes are soaked. I tried to run the washer and see if it would spin but still nothing. It will poar the water in but that is all it will do. I don't know what else to do. Please help?
  • Anonymous Sep 01, 2008
    same problem. clothes are sudsy and soaked
  • holdy Sep 05, 2008
    same problem
  • Carl
    Carl Sep 30, 2008
    Same thing !! Everythig is fine,, just wont go to high speed spin..
    I read here it could be the door switch.. I read elsewhere it could be the speed control board..
    Ahhhhh HELP !!!!!!!!
  • shoosie Oct 01, 2008
    My frigidaire front load washer GLTF2940ES3 doesn't spin in high speed. It goes through the tumble action but no high speed spin. It is 2 years old. I put the machine on drain/spin setting which is about 13 minutes. It seems to count down to 9 minutes remaining rather fast, while draining/pumping only. At 9 min remaining, it then begins to rotate back and forth. At 7 minutes remaining it just beeps and shuts off. I never get the high speed spin. cycles, everything seems to work but the high speed spin cycle. There also seems to be a lot of water trapped in the rubber ring, It is very stale and musty. What should we do?
  • twins01 Oct 06, 2008
    my frigadaire front loader will not go into a spin. I thought it was the pump but now not sure.
  • blackolds98 Jan 16, 2009
    It was the door switch. I didn't have the warranty, but it turned out this was a very common problem and was considered a warranty / recall. After the switch was installed, we have had no other problems. BTW, only licensed Frigidaire repair tech's can work on Frigidaire machines. My same day service guy could not.
  • Anonymous Apr 28, 2009
    My machine gets down to 11 minutes remaining and then stops, it will not spin, leaving the clothes soaking wet. It has a manufactuer date of 06/06, and stopped working around 04/09. It is used heavily , about 4 washes per day.
  • ssasqch60 Apr 29, 2009
    same problem  got error code E47
  • Anonymous May 02, 2009
    Clothes come out soaked! Never goes into high speed spin!
  • Anonymous Mar 21, 2014
    I have a frigidaire affinity front loader and it will say no water and my clothes don't rinse out good
Just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
I wonder if your machine is housed in a basement environment. We have found that the timer to allow it to rotate to other parts in the cycle swells with the humidity and the machine won't advance through cycles. Our machine too is a year and a half old, has very little use on it since it is a part time home . We removed the timer, the gear shrunk back so it turns again, but this will obviously be temporary if the basement humidity stays high.
Posted on Jun 03, 2008
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Oct 01, 2010
i have the same problem o with this machine, technician came in and replace computer board and motor, for nothing after installing these 2 parts he found that the problem is the lock...as was described by frigidaire technical support.
Posted on Nov 02, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire front loader washer won't go into spin cycle after the clothes are washed
Sounds like you need a technician to diagnose the timer of the unit. Also the sensor that communicates to the timer.
Aug 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle not working
you will need to unplug the machine and take off the back panel and look for a small 5mm pipe leading upwards, take it off and blow gently into it you should hear a click and another one when you let the air out again if so then the small pipe where you took it from is blocked preventing the switch to work properly , unblock the pipe with a pipe cleaner or metal rod its normally full of soap goo return the pipe and close the back up and run the machine again eric
Jan 05, 2018 | Frigidaire GLTF2940ES Front Load Washer
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
My washer wont spin
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
2,173 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
