Question about JVC AM FM CD DET FACE CAR STEREO
I need help on the wire diagram for connecting a JVC KD-G 245 car radio. I believe that 4 pairs of wires (black striped and plain) white, green, gray and purple are for the speakers. What about the other 4 wires; blue/white, red, yellow and black? The blu one has a fuse while the red and yellow pass through a black box that has a fuse and coil. please help.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 2,226 Answers
Blue/white is amp remote turn on, red is ignition (switched hot pos.), yellow is constant hot, and black is ground (neg.)
Posted on Oct 07, 2010
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
I would like the wiring instructions for a jvc kd-g845
Wiring harness connections as described in the installation manual:
  1. Black: Ground to metallic body or chassis of car.
  2. Yellow: Terminal in fuse block connecting to car battery (bypassing ignition switch) (constant 12 V).
  3. Red: To an accessory terminal in the fuse block.
  4. Blue: Power antenna if any (250 mA max).
  5. Blue with white stripe: To the remote lead of other equipment (200 mA max).
  6. Orange with white stripe: To car light control switch.
Speaker connections:
Left front: + White - White with black stripe
Right front: + Gray - Gray with black stripe
Left rear: + Green - Green with black stripe
Right rear: + Purple - Purple with black stripe
Jul 17, 2011 | JVC Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
What color goes to which speaker?
Check the following link:
http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
The directions on page 4 indicate:
White = Front Left Speaker
Gray = Front Right Speaker
Green = Rear Left Speaker
Purple = Rear Right Speaker
The plain colored wire is the + side of the speaker.
The colored wire with a black stripe is the - side.
Hope this helps!
Feb 05, 2010 | JVC KD-G230 CD Player
I need a wiring diagram for a JVC KD-R805 installation
For putting it into what kind of car? Or did you mean the radio harness itself? Red is constant 12v, yellow is Accessory 12v, Black is the ground. Solid blue is power antenna, blue with a stripe is a 12v accessory meant to power the amp (AKA AMP REM), White is front left speaker, gray is front right. Purple is rear left, green is rear right and any of the white,gray, green or purple wires with a black stripe is the negative for that speaker. If you post a reply with a vehicle model and year I can give you the factory wire harness colors as well.
Jan 13, 2010 | JVC KD-R800 Car CD/ MP3 Player
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
Car radio connections
Red wire to acc fuse
yellow= b+ fuse
blue= to amp amplifier
white= +left front speaker
white/black left front - front speaker
gray= + front right
gray/black= - front right
green= + rear left
green/black= - rear left
purple= + rear right
purple/black= - rear right
black = ground---to car metal
orange with white line to illimination
Apr 15, 2009 | JVC KD-G110 CD Player
Jvc unit
check down the radio. down the radio is the diagram chart.
Aug 16, 2008 | JVC KD-G140 Car CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
101 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
