Question about Jabra JX20 Bluetooth Headset JX20 Pura
Hi , my jabra jx20 Pura bluetooth connects and pairs with my handset, but I am not able to hear anything !!
3 Suggested Answers
SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
Posted on May 20, 2008
SOURCE: JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Posted on Jul 22, 2008
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
How can I pair my Jabra BT2035 with my ps3
After registering the bluetooth device ( in the settings> accessory settings> register bluetooth device) you must then go to the audio options in the settings >accessory settings >audio options and switch the input from do not use to use to the name of your bluetooth to turn on the connection from the bluetooth to your ps3
Apr 16, 2010 | Jabra Cell Phones
This is my first bluetooth and I'm having a problem getting my Jabra BT125 into discovery mode
The Jabra goes into discovery mode when the unit is off, and the power button is pressed for ten seconds, which passes the five second power on time.
At ten seconds the unit lights constant to state discovery mode is on.
See the manual on Pairing:
To download the PDF of the Manual click here. This is page 6.
Dec 12, 2009 | Jabra BT125 Headset
Jabra bT260s Pairing problem...
You may need to change your output sound device. The method may vary depending on your software and hardware, but go to Start -> Control Panel -> Sound (I think. Doing this from memory, so might be slightly off). There should be a Devices or Output tab. Change that to your bluetooth headset. You will probably need to restart WMP before you hear music, too.
Jan 18, 2009 | Jabra BT620s Consumer Headphones
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
How to pair Jabra BT620s Bluetooth headphone with HP Laptop?
Hi
• At your computer Right click on the Bluetooth icon on the task bar.
• Select “Explore my Bluetooth places”.
• Click on “View devices in range” to see all available devices.
• Right click on the Jabra BT620s and select “Pair device”.
• Enter the four digit passkey: 0000 (4 zeros).
• Right click on the Jabra BT620s and select “connect”.
• The connection will be established automatically, otherwise if the Jabra BT620s is ringing,
press the answer/end button to confirm the connection.
Good Luck
Aug 10, 2008 | Computers & Internet
Jabra bluetooth headset
  1. Start with your Bluetooth headset powered off
  2. Hold down the Answer/End key for 6 seconds. Light will turn solid blue.
  3. Release Answer/End key, Light will remain unchanged.
  4. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset.
Jun 14, 2008 | Cell Phones
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Jabra BT 320s Headset
If you have no problem pairing the headset to the cellphone, maybe the issue comes from the headset that has a defect in it. These bluetooth headsets are kinda fragile, check out where you bought it if you have a warranty.
May 21, 2007 | Motorola Mobility V170
Jabra JX20 Bluetooth Headset JX20 Pura Logo
29 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
