Me computer when i open it automatically shutdown
  • 40 Answers
Its has a trojan virus maybe that affect your computer, u have to format ur hard disk to fix it.
Posted on Oct 07, 2010
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
Tip
How to restart or shutdown a computer through a remote desktop connection
When you are connected to another computer by remote desktop, did you ever notice that the shutdown and restart options are not there. The computer that you remote desktop to must already be on. But if you regularly use remote desktop, at some stage you will want to restart the remote computer from where you are. For example you might install a program and you need to restart the computer to finish the installation. If this doesn't happen automatically then you can follow the steps below.
How to Reboot or Shutdown a Machine from Remote Desktop Connection using Windows XP?
  1. Open the run box by pressing the WINKEY and the letter R on the keyboard.
  2. Type the following command into the run box: shutdown -r -f
  3. Press Ok.
  4. This will restart the remote computer.
If you would like to shutdown the Windows Xp remote computer you can type: shutdown -f
When you are typing these commands in you must type it exactly right. If you miss a space or a dash it will not work.
Restart a remote computer using Windows Vista or Windows Seven.
On these newer operating systems the run box is almost obsolete. You only have to open the start menu and type these commands into the search bar at the bottom. This area acts as a run box and you can type commands into this.
on Jan 29, 2010 | Computers & Internet
The benq Monitor FP222W automatically shutdown
Check if you dont have a timer shutdown on the menu.
Electronical Problem:
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Feb 14, 2013 | BenQ FP222W LCD Monitor
I set shutdown time at 10 pm by using crontab but server shutdown at 1800 or 6 pm . I am using LINUX CentOS
Hi
Try using ttps://launchpad.net/gpoweroff also the other way to set auto shut down is
Also another way is
A simpler way is to add the appropriate shutdown command to the /etc/profile file (as root):
Open a terminal window and su to root:
[user@localhost ~]$ su
Password: (enter root password here)
This example will open /etc/profile in the kate text editor:
[root@localhost user] # kate /etc/profile
Add the following command to the end of the file:
shutdown -h hh:mm
Replace hh:mm with the time at which you want the computer to shutdown automatically each day
The -h option tells shutdown to turn the
computer off (halt).
For more information on the shutdown
command open a terminal window and enter:
man shutdown
Remember, the man command is your friend.
With it you can get information on nearly
any command available in your Linux system
Let me know if this helps
Mar 17, 2010 | Fujitsu Siemens Siemens PRIMERGY RX300...
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | HP Pavilion 110-1030NR Notebook
System shutdown message pop up and shut down and restart computer
Jan 22, 2010 | Computers & Internet
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
PC automatic shutdown
logon.ddl has been missing u hv to reinstall ur operating system
formate ur pc it will solve ur problem
Jan 29, 2009 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
David Payne
David Payne
