Question about Nikon Cameras
Nikon fa how do i start ? how do i get the film out i need the basics
  • 667 Answers
On all of that series of Nikon SLRs, there is a small black plastic tab under the rewind handle on the left side of the camera. (as looking from the back). The tab needs to be pushed lightly and that will release the rewind shaft so you can pull up on the rewind knob to open the film door.
more info can be found here on Fixya
The FE2/FM2 are very similar in operations and function
Posted on May 31, 2008
How to open back of nikon fa
Pull the rewind knob up, Back door will open,
Oct 14, 2013 | Nikon FA 35mm SLR Camera
My FA camera shutter release button won't work, no reaction when depressed and look through the view finder was dark.
The dark viewfinder usually means that the battery must be replaced as the mirror has fully or partially locked up. A new battery usually fixes this instantly. The stuck shutter release can also be due to a failed battery or is due to the shutter lock being engaged. The lock is disengaged by pulling the film advance lever back slightly.
You can download free instructions for your camera courtesy or the Norman Butkus website; if you find his information useful then consider making a donation as he suggests toward his site running costs.
The battery is either two SR44's or LR44's, the latter are cheaper but give less accurate exposures due to their unstable voltage output, but if you're shooting on negative film instead of transparencies you'll be unlikely to spot the difference. A single CR1/3N battery also does the same job as two LR44's but is harder to find and more expensive than two of the very common LR44's.
Feb 18, 2011 | Nikon FA 35mm SLR Camera
I purchased a used Nikon FA camera for my daughter to use in her photography class. None of the pictures came out during developing. Any ideas what the problem could be? I was only given a 7 day return...
If it's still within the 7 days take it back. The Nikon FA was a great camera but time and lack of use has probably caused the shutter to seize. To put this camera back into serviceable condition for any photography will require a clean, lubrication and adjustment by a qualified camera person. I'm in Canada and have cameras service fairly regularly older ones to have this type of work performed will cost about $120.00 Canadian. The instructor is probably asking for the students to have a manual camera to be able to learn from the ground up which to me is the best way but, these old cameras are failing just because the grease is drying out. There are still a lot of good used working camera out there I just bought a great Canon Elan 7Ne for $199.00 CDN and it's a 2005 model the last year of the Canon film cameras. I guess it depends on if you want to spend the money (and time) to get the FA repaired or step into something for a little more money that works properly right from the get go.
Jan 24, 2011 | Nikon FA 35mm SLR Camera
Shutter speed unpredictable
Older film cameras have the lubricant dry out and it begins to drag the shutter speeds down some like the Canon "A" series will even begin to squeak when the shutter is released. The Nikon FA's are great classic cameras and if in good cosmetic condition it's often worth having them repaired. I don't know where you are but in Canada a clean lube and adjust would be about $130.00, I'm sure less in the US. I still have several film cameras in my "fleet" although used less then once before they still produce great pictures. Happy Holidays from Canada
Dec 23, 2010 | Nikon FA 35mm SLR Camera
HOW TO GET STARTED WITH NIKON N65, I DO NOT HAVE A MANUAL. HELP PLEASE.......TNX.
Basically, you insert batteries, load film, attach a lens, point the camera, and press the shutter release button :-)
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 11, 2010 | Nikon N65 35mm SLR Camera
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Nikon FA top plate removal
After unscrewing the rewind knob, remove the circlip under it. Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Mar 22, 2009 | Nikon FA 35mm SLR Camera
Putting film into nikon f60
It is fairly simple. Insert the film canister with the hole side (not the projection) down. Insert the spool of the camera into this hole and slide the canister inside the chamber. Now pull the film out slightly so that the leader (the narrow portion at the end of the film) aligns with the orange mark at the lower right end of the film chamber. Make sure there is no slack in the film. Close the door and turn on the camera.
Mar 13, 2009 | Nikon F60 35mm SLR Camera
Nikon FA will not advance. Meter will not give reading.
the capacitor is bad or the circut has a fault somewhere. You will need to take it to a camera tech or just use it in the manual moide only
Jan 14, 2009 | Nikon FA 35mm SLR Camera
Nikon FA Aperture Index Ring
It is likely that I have one, used of course. Let me know
Jul 06, 2008 | Nikon FA 35mm SLR Camera
Cameras Logo
57 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
