Question about Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display
I have used parrot on the same phone for months with no problems but now the mute symbol comes up on the display and the headset symbol is on my phone in the paired device display. i have tried using another phone but have the same problem. can u help?
4 Suggested Answers
SOURCE: Unable to pair Nokia N85 to Parrot car Kit
for all G3 phone try: Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
Posted on Jun 15, 2009
dancandoit
  • 436 Answers
SOURCE: I have a new phone nokia 6303 and tried pairing
you need to go to settings / paired devices / delete any old phones that are still stored as the parrot will only allow 5 paired devices. then try again. You may want to check your software and if your software is over 12 months old it will be a good idea to update your parrot, try parrot.com/support for more.
Dan
Posted on Mar 03, 2010
SOURCE: pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Posted on Mar 27, 2010
My parrot handsfree kit keeps muting itself when i answer a call do you have a solution?
This will need a software update, you will need a laptop with Bluetooth and download the update manager from Parrot.com. otherwise you can also find all parrot engineers on the web site.
Oct 17, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My Parrot CK3100 will not seem to switch off when the ignition is turned off and the car is locked. The display seems to remain on 24x7 and now seems to be draining the car's battery. Any idea how to...
Hi there, my Parrot CK3100 screen just says "Goodbye" how do I switch it back to the Parrot symbol, so I can pair it up to my Samsung Wave via bluetooth. My phone is connected to the device, but the divice is not connecting to my phone?
Jan 24, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I need to install a new phone and the parrot doesn't admit the pass 1234. I don't know what I have to do now! please help me! My parrot it is a parrot minikit.
Problem :
Password for Bluetooth
Solution :
Most bluetooth headsets use a universal "0000" (four numerical zero's) for the passcode
please rate my solution
Aug 23, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
After using the parrot to make a call on Friday, my radio has stayed muted. Normally, after ending the call, the radio comes back on after a few seconds. CDs also are playing, but are also muted.
it sound like the software has locked u you will need to have new software put into the box, this can only be done using an update cable. try parrot.com and find you nearest engineer.
Apr 26, 2010 | Parrot Par Ck3000 Evolution Ck3000...
Wont audio to headset
The problem with the Blue Parrot headset not getting audio from the phone is a very frustrating one and it took several hours to diagnose the problem. (Especially the Samsung/ Windows side, in my case)
I have a Samsung I760 phone using Windows Mobile 6.1. After pairing, the headset is visible in the PHONE window, as it should. But upon dialling, the audio transfers from headset to phone.
While in a call, you can tap on the menu button and it should bring you to a menu that would allow you to transfer the audio from headset to phone and vice versa. But this action malfunctions in the Blue Parrot headset only. The Blue Eagle headset works fine.
MY SUGGESTIONS:
1) Chuck the hideously expensive blue parrot headset in the trashcan and buy yourself a blue eagle, available at truck stops everywhere
2) Pester the Blue parrot support staff for a replacement, or a solution at 1800 742 8588.
Make sure you understand the manual and especially point 13 dealing with the transfer of audio before you call them.
Other than this, the headset actually works fine.
adampotgieter@yahoo.com
Dec 15, 2009 | VXI Corporation Blueparrott B250-XT...
Cant pair parrot to nokia 5800 was paired but accidently deleted all devices. I only need the 5800 paired. no paired devices is displayed on screen. have kept bluetooth on phone displays the parrot wont...
you will have to pair them together again, search for devices from your phone and select parrot, then enter pin code 1234 when prompted, this should then pair again.
Nov 14, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Mute the audio system when
yes the yellow wire is mute and needs to be connected to the mute on the back of your radio.
Nov 06, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot evolution
There is a tiny reset on the back of the parrot. Use a paperclip to depress and reset the device. This should remove any pairings.
Jun 20, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot SA Parrot Ck3100 Lcd Handsfree Bluetooth Cellular Kit With Display Logo
252 people viewed this question
Top Parrot SA Cell Phones Experts
Al
Al
Miroslav Rusev
Miroslav Rusev
repairphone
repairphone
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
