Question about Dryers
Hoover 5030d dryer wiring diagram and service maual
huuum
  • 750 Answers
SOURCE: Hoover Dryer 5030D does not heat up
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Oct 06, 2008
  • 12 Answers
SOURCE: dryer not heating hoover 5030d
Some dryers have a thermo-fuse. It doesn't look like a normal fuse. It can look lide another thermost or a long plastic device with two wires foing to it. Also they have a high limit thermost that can open. There is a switch on the motor that won't let power go to the heater until the motor reaches a certain RPM. If this is a 220 volt dryer, it could also be the house circuit breaker. If one half of the breaker is bad or tripped, the motor can still run but you will have no heat. If the dryer has a heat selector switch IE delicate, no heat, or high heat. You should check that for continuity when in one of the heat selection positions. The timer can also cause no heat. Check the timer contacts when it set in a dry cycle. Hope this helps.
Posted on Nov 20, 2008
  • 11 Answers
SOURCE: Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: my Hoover dryer model 4030D heavy duty needs a new
HI. you can order your timer by calling this number. this is a parts store that will ship your timer to your door step or mailing address..
1-866-925-PART (7278)
Just tell the Representative your model number and brand name of the affected unit and, they will search for it on there data base. when found, they will ship it to you after you purchase it.
Posted on Jun 18, 2009
  • 353 Answers
SOURCE: My hoover dryer is not heating to full heat and is
change element and or thermostat
Posted on Aug 11, 2010
There are other question and answers about Hoover dryers model 5030D in the related questions section
?????? ???????? ??????? ???? ???? ??? ??? ???? ??? ????? ??? ?????? ?? ????? ?????? ???? ???? ?????? ????? ????? ??????? ???????? ??? ?? ???? ?????? ?????? ??????? ???? ???? ??? ???? ??? ??? ???? ?????? ??? ???? ???? ?????? ??????? ??????? ????? ????? ??????? ????? ????? ???? ????? ??????? ??????? ???? ?????? ????? ?????? ??????? ? ???? ????????? ???? ???? ????? ????? ??????? ?? ????? ?? ???????? ???? ???? ?? ?????? ???? ????? ??? ??? ??????? ???? ??? ???? ???? ??? ???????? ?????? ????? ????? ?????? ?????? ???? ?? ?????? ??????? ???? ?????? ????? ????? ??????? ???????? ?? ??????? ???? ?????? ????? ????? ????? ???? ??? ???? ????? ????? ????? ?? ???? ??? ????? ?????? ?????? ????? ???? ???? ?????? ????? ???? ??????? ???? ???? ?????? ?????? ????? ? ??? ???? ????? ??? ??????? ????? ???? ??????? ??????? ????? ????? ???????? ???? ?? ?????? ?? ???? ???? ??????? ? ??????? ???? ???? ??? ???? ???? ??? ???? ???? ????? ??????? ???? ???? ???? ???? ???? ?????? ????? ???????? ??????? ???????? ? ????? ????? ??????? ???? ?????? ????? ????? ?????? ???????? ???????? ??? ???? ???? ??? ?????? ?????? ???? ??????? ?????? ? ?????? ???? ???? ????? ??? ??????? ????? ??? ??? ???? ???? ???? ?????? ?????? ?? ?????? ????? ????? ???? ???? ??????? ???? ???? ????? ????? ??????? ? ???? ???????? ??????? ???????? ???? ??? ???? ????? ??????? ???? ???? ?? ????????? ???? ???? ??? ??? 99% ???? ????? ????? ???? ????? ?????? ??? ???? ??????? ???? ??? ?????? ?????? ??????? ?? ?? ????? ????? ???? ?? ???? ????? ???? ???? ??? ?????? ?????? ????? ???? ???? ???? ??????? ?????? ?????? ?????? ?????? ? ???????? ??????? ???????? ??? ???? ????? ?????? ????? ????? ?? ???? ?????? ?????? ?????? ??? ???? ????? ???? ???? ????? ????? ???? ???? ??? ???? ??????? ???? ??? ??????? ?????? ??? ?????? ??????
Feb 11, 2016 | Hoover Dryers
Hoover dyrer 5030d not getting warm
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 03, 2011 | Hoover Dryers
Hello, i have a hoover dryer, model 5030D, secondhand, it is just been purchased my us. we put on our first load on and the machine stopped within 15minutes. we noticed then that the machine was...
Hi, if I remember correctly this model originally came with 2 faceplates so the controls can still be easily accessed, when the dryer was installed upside down on a wall. Most dryers can be run upside down, or even on their side as I done in the past with my Hoover 5030D, so the problem would lie elsewhere.
Dec 26, 2010 | Hoover Dryers
My Hoover dryer model 4030D heavy duty needs a new
Jun 18, 2009 | Hoover Dryers
Dryer not heating hoover 5030d
Nov 20, 2008 | Dryers
Drier
I just saw this model advertised in Australia online and they said, less than a year old!
model 5030D???????????????????
I would not buy a used appliance!
Just putting good money into bad. Unless I can afford to fix it.
And I f so I would be better buying a cheap new one and take the extended warranty in today's market.
But everyone's not me!
Huuum
Sep 23, 2008 | Hoover Dryers
I have a Hoover 5030d & its making a noise as the barrell turns. If spun manually it sounds a bit like a bearing. Is it easy to change a bearing on a Hoover 5030d?
It sounds like the engine shaft bearing. Fairly simple to fix or replace with the correct tools and know how.
Be sure to take photo's of the motor, tension arm, and any wiring.
You'll need pliers to remove the clamp from the fan, then remove the belt from the motor and make sure that's were the problem is before going any further.
Jul 06, 2008 | Hoover Dryers
Dryers Logo
363 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
