Question about Whirlpool Refrigerators
When trying to remove my water filter from my whirlpool fridge, the screw end that fits into the fridge broke off. How can I get through the "tube" to remove that piece so I can put in a new filter?
    Problem Solver:
  • 14 Answers
Purchase a screw extractor the right size. It's like a reverse fluted drill bit. Use an appropriate extension and a reversable drill. Or.. find or cut a round piece of rubber in a cone shape of the right size to insert and grab the broken piece to spin it out CCW.
Posted on May 29, 2008
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this:
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
My fridge started leaking when I try to dispense water.
The drain is clogged. Get to the drain like you did before. Get a straw, use some tape and wrap it around the end of straw to make a tight fit for the drain hole. Blow into the straw to remove the clog.
May 15, 2016 | Whirlpool Refrigerators
Why does water filter leak when tightly connected but not when loose?
It makes sense if there is a crack in the filter housing that is made more severe by tightening the fitting. Also, a fitting could be stripped from overtightening.
Aug 11, 2015 | Whirlpool Refrigerators
Change water line
I think there is a panel that need to be removed on the back of your model.
Appliance 911 Sea Breeze
Aug 02, 2015 | Whirlpool Refrigerators
Frigidaire water filter stuck
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Oct 02, 2012 | Frigidaire ULTRAWF Frigidaire PureSource...
Water filter won't release
Is it a push fit or screw in? Gently push up and twist anticlockwise if it's screw in. If it's push fit depress the inner part where the hose goes in and pull the hose at the same time. MAKE SURE the water tap is off before doing it and preferably unplug the fridge too.
May 01, 2012 | Frigidaire Refrigerators
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Frozen, broken kenmore fridge water filter
Hello Leslie176,
They are called reverse twist bolt/screw extractors..
The prettiest I have ever seen came from EASTMAN restoration products..
You are looking for the variable sized set that fits into an ordinary soct wrench with... EXTENSION (should get you into the filter housing...
You will hhave to replace the whole Filter housing
IRWIN HANSON Hex Head Multi Spline Screw Extractor Set 25 Piece 53227 Hex...
Check out the eBAY version
(you don't need QUALITY STUFF for plastic
Hanson AHN53204 7 32 034 Hex Head Multi Spline Screw Extractor Bulk NEW...
Apr 13, 2017 | Frigidaire FRS3R5EMB Side by Side...
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
