Question about Microsoft Xbox 360 Console
Motherboard support Is there a reason why a white eraser is used in order to support the CPU/GPU on the motherboard, or will any eraser (3mm-4mm) work?
  • 37 Answers
A: Its not the cpu/gpu but actually the ram.
B:I used 3 copper pennies instead of an eraser and it works 10X better.
Posted on May 29, 2008
How do i fix error code 0023 on xbox 360.
This is a confirmed error code on either the GPU or CPU(most of the time the GPU). Your console got way to hot and cooled off, got way too hot and cooled off etc etc a multitude of times and created hair line fractures in the .06mm solder balls under either the CPU or GPU. Microsoft really screwed the pooch on first(white/phat) generation consoles by three things. Bad heat sink design for both the CPU and GPU, Bad tin/lead solder combination, and bad airflow. To resolve this you would either have to send the motherboard into microsoft to have both the CPU and the GPU undergo a process which is called reflow, AFTER both were lifted from the motherboard and replaced with a higher quality solder AND THEN upgrade the heatsinks to something of higher quality. I even go the extra mile on these things and dremil out a large hole on the top of the case to duplicate a fan install that you see present in the black models.
Sep 11, 2014 | Microsoft Xbox 360 Console
I'm building my machine and I get the lowest score on my cpu. I have a P5b-vm SE motherboard and was wondering what cpu I could use to help out. I like to game such as dota 2. It's got a really bad lag. I...
CPU is mostly not issue for playing games, not in late 20xx ...
In most cases its GPU (Graphic card) and you didn't give specification of whole computer.
P5b-vm SE could run on Quad core CPU. You didn't mention your CPU as well ?
So can you please share more info, CPU, GPU, Memory, ... no matter of the score.
Oct 14, 2013 | Computers & Internet
All of a sudden all my red colors are faded and almost show grey like it was in black and white or something. All the other colors seem to be fine. What's up?
You have beging signs of yellow light of death and will need to reflow the cpu and gpu with a hot air gun. Cpu and gpu are inside bolted to the radiator. You will have to break the ps3 down to just the motherboard and will also need some new thermal compound paste.
Feb 18, 2011 | Sony Playstation 3 (PS3) Console
My dv6000 will power up and go back off
This model of laptop has an overheating problem. This problem affect the Nvidia GPU and cause that issue. You have two options, one cheap and one expensive.
The cheap one is that you must overheat the Nvidia GPU, in order to resolde it again. This procedure you can make it with a Heat Gun. I mean you need to extract the motherboard and apply the heat directly to the GPU 90 seconds max. Put all the pieces together again (dont forget to apply thermal paste to CPU and GPU) and when the laptop turn on again, go to the HP website and download the las Bios update to your model.
This solution give you as long time as you work with your laptop fresh. You can download the CORETEMP application, to keep watching the CPU temperture.
Cost: $ 20 Heat Gun (harbor freight), $ 7 new thermal paste (for the CPU and GPU)
The expensive one is send your computer to a authorize service center and ask for a reballing repair to your GPU. Cost may be $ 200.
If you need more details, let me know. GOOD LUCK
Feb 16, 2011 | HP Pavilion dv6000 Motherboard
I reflowed my motherboard but didn't flux it. the ylod was fixed for around 3 hours. it has come back on. am going to try and reflow again tonight. should i flux it if so where do i put the flux. also is...
Hi there. I use flux every time I do a reflow. The reason for this is that it helps the molten solder flow much better and stops oxidation of the solder which can cause bad solder joints. The whole point of a reflow is to "mend" the hairline cracks that have appeared in the solder under the GPU and the CPU. Without flux this is harder to do. As to where you put the flux, you need to actually put around 4-5 drops on one side of the GPU and CPU and then tilt the motherboard so it runs underneath the chips. Do that for each side. Do not worry if the flux goes on other components, if you use "no clean" flux this is fine and will not do any damage. You basically need to make sure that the GPU and CPU are thoroughly "wet" underneath them where they are soldered onto the motherboard.
If a second reflow does not work or the fan speed increases to maximum after only being on for a short time then it is highly likely that the GPU or CPU have actually been permanently damaged from either the reflow or the original overheating. Only a replacement is going to fix this.
Also make sure you hold the air gun about an inch away from the chips for around 20 seconds. If you have a heat gun you can set to around 300 degrees celsius, all the better. If your heat gun is one that does not have adjustable heat settings, be very careful how long you heat the GPU and CPU up for. More heat means less time heating the chips
Hope this helps
Feb 12, 2011 | Sony Playstation 3 (PS3) Console
3 red ring, of course, is it safe or a "reasonable" solution for me to repair it myself?
You can repair the 3 red ring yourself using a good guide, or you can send it in.
All it is is too much heat between the GPU and the CPU, the motherboard bends the soldering snaps off and you have the 3 red light.
Stop the heat and the motherboard from flexing and you have no problem.
Hope this helps.
Dec 20, 2009 | Microsoft Xbox 360 Console
Cpu
The noise is coming from fan friction and vibration. Running compressed air through fan components can help reduce noise pollution from dust buildup. Brush-less CPU/GPU fans are significantly quieter than the brush-motor powered fans that come with some factory electronics. Furthermore, some computer cases are designed with noise reduction in mind; Antec designed cases are know for being one of the quietest because they use patented bushings to secure the computer hardware. Moreover, make sure internal wiring is free and clear of all fan blades.
Mar 11, 2009 | Intel D101GGC Motherboard
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
