Question about Dell Dimension 2400 PC Desktop
Slow computer I have this model dell which was purchased brand new several years ago - maybe 4-5 and was upgraded before shipment to whatever they recommended at the time. We now have broadband which helps immensely but my computer seems draggy. I have regcure, webroot spy sweeper, firewall and had McAfee but won't let me update software. I only use for some small document torage, not too many pics and shows I have plenty of room on computer but use mostly for web browsing and emails. Any help with slow computer or should I call Geek Squad?
My dell 2400 has 40GB HD. I want to upgrade to the biggest HD my 'puter can handle without exploding. So how big of a HD should I buy? Please talk to me like I'm an idiot. (I am.)
I will also be upgrading memory to 2GB.
Posted on Jun 24, 2008
Go to start - all programs - accessories - system tools - deframentor. Then anylise and if it says you need to deframgment do it. It bunches the Items on your hard drive together to make the space you have, accesable.
Posted on Jun 23, 2008
  • 165 Answers
Cheap fix:
A dimension 2400 typically came with 256 or 512M ram, upgrade ram and you should see a big improvement for around $15
newegg recomended:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820161615
for 512M. put 2 in for 1 gig
With each patch and service pack, windows XP is getting bigger and bigger. I had 12 machines with 512M that worked great a year ago and now became dog slow, upgraded all to 1 gig and now users all saw a dramatic improvement.
Posted on Jun 16, 2008
  • Philip Markert Jun 16, 2008
    ps... these 12 machines were carefully maintained and had nightly virus and spyware scans, and sit behind a business firewall.
  • 43 Answers
Well you pretty much answered your own question.
The computer is old (simply put). The only thing you can possibly do to speed it up is to make sure you don't have alot of things running in the background. The only thing the Geek Squad is gonna tell you is its time to upgrade which you already know.
to turn things off in the background
click the start menu
choose run
type in msconfig.exe
go to the startup tab
uncheck anything you don't need running (I would suggest unchecking everything you can start them on your own)
then restart
basiclly what you just did is turned off every program that starts when windows does. This saves your computer from using ram on uneeded programs.
Posted on May 29, 2008
    Sergeant:
  • 458 Answers
Geek squad will charge you a lot and not do anything. Uninstall McAfee and spy sweeper. McAfee slows down all computers.
Do the following and let me know if it helps.
Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website (tandnfamilyelectronics-online.com). These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer. This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. (dean@tandnfamilyelectronics-online.com)
Send me the complete specs of your system and I can help you more. I hope that this helps you. There is no reason the really buy a program for spyware when there are free things to use that work great. Free AVG is a great Antivirus and yes it is also free. It will check your e-mail coming and going. It will also let your friends now that the E-mail does not have a virus. It also has a spyware program that is free. This day and time with all of the spyware out on the net you can never have too many programs for spyware. I would not run all of them at the same time though. Make sure that you do not use your computer during any scan. Defrag is also something to do after you do everything else. Some people will tell you that should not reload your computer. If nothing seems to work then sometimes that is the only good way to get it repaired right. Most of the programs that come pre-installed on a store bought computer is useless and most are even trail software that causes problems when they expire. Let me know if this helps at all. Please rate me if it helps.
Window Washer free Link
Please rate me if this helps.
There are a couple of things I do to help with speed....
Partitioning:
If you wipe your computer again, create one partition for your system for 20-25GB for system files; Afterwards, right click "my computer" disk management: create a NTFS partition for the rest and store any personal files in this drive.
My Computer: Properties
Start\My Computer (right click)\Properties\Advanced\Performance\Settings
*Check the best performance box; then check the bottom two boxes eliminates cursor shadow
etc. (this will get rid of cursor shadows etc)
Start\My Computer (right click)\Properties\Advanced\Performance\Settings\Advanced\Virtual Memory\change
*Computer Managed: Or Type (1.5x size of ram on computer = minimum; 3x size= Max; ex: if you
have 256Mb of ram; min= 384Mb; max= 758. outside of this ratio might be slower.)
Folder Properties:
Start\My Documents\Tools\Folder Options\View\..uncheck
*Automatically search for network folders or printers (Regardless if you're on a domain, the computer will try to search for everything all the time.)
Registry Tweak:
There are things you could do here but see if the previous could help.
Posted on Nov 02, 2008
Hello there,........i have a samsung digimax s500cyber530 that i bought appox: 4 years ago?,.....and we just several days ago replaced an 8 year old gateway "windows" computer w/a brand new HP...
Once you get the camera working again by the "shuffling technique", don't connect it to the computer again. Instead, purchase an inexpensive card reader and use it to download pictures from now on. typrice_31.jpg
Nov 17, 2010 | Samsung Digimax 530 Digital Camera
I have a Dell OptiPlex 160L System computer and need to upgrade my graphics card from 64MB total memory to at least 512MB, but prefer 1G plus to handle graphic and fashion design software including digital...
Since you can't upgrade memory on a video card especially if its built on to the motherboard your best bet is to purchase a new PCI video with the proper amount of memory you need and install into your dell PC. you may have to go into the BIOS and disable the on board video card and tell the system to use the new one. Just make sure the new card you purchase has drivers for whatever operating system you are running.
Aug 10, 2010 | Dell OptiPlex 160L (160LMIN) PC Desktop
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
System upgrade
You did not post what operating system you have. There are a lot of things that can cause a computer to run slow. RAM is big issue More so than the CPU. The series of CPU that you have is upgradeable by 4 models but the gains are modest. There is also an issue of availability of the processor because that model is 12 years old. Another issue that you need to look into is the programs that are running when the system starts.
Feb 18, 2018 | Dell 2.8 GHz Second Processor for...
Upgrading my laptop processor
When you're running an average load, start Task Manager and view the performance tab. If the amount of free RAM is low, then definately upgrade your RAM. Plus, nowadays it's really cheap to upgrade ram.
As far as upgrading your processor, that can get a little tricky and expensive.
Also, what do you mainly use your computer for, and what operating system do you use?
Jul 26, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Should I get a new cpu for dell dimension 3000?
HII MARLBOROMANZ ,
YEAH THE PROCESSOR IS BIT SLOW FOR GAMES TO RUN PROPERLY.
I WOULD SUGGEST U TO BUY MOTHERBOARD THATS INTEL 965G AND CORE2DUO PROCESSOR.
U DONT NEED TO UPFRADE THE RAM AND VIDEO CARD U CAN USE THEM IN NEWLY UPGRADED MOTHERBOAD AND PROCESSOR.
I AM SURE U WILL ENJOY GAMES IF U UPGRADE ONLY OTHERBOARD AND PROCESSOR.REST ALL IS FINE.
Nov 03, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 2400 PC Desktop Logo
151 people viewed this question
Alun Cox
