Question about Watches
I purchased a howard Miller's Grandfather's clock in 1984 by the name "The Brandeis" Model # 610-305, with a # 155 wt. driven pendulum. We moved it to put in a new floor & now we have no idea which weights go where. Can you tell me where to put the heaviest one & etc.? Also need info on where to oil it & with what type of oil. The chimes have not worked properly for many years therefore I need all the free info you can possibly share with me. Thank you, Candy llamas2169@gmail.com
  • 744 Answers
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Posted on Mar 29, 2009
  • 12 Answers
SOURCE: What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
Posted on May 02, 2009
cmcduncand
  • 714 Answers
SOURCE: How do you determine what side of the chain that
We would like to talk you through this problem.
If you want to call, My number is on my profile.
I am available afternoon Feb 25 you are welcome to call.
R/
David
http://antiqueclock.clockstop.com/
Posted on Feb 25, 2010
SOURCE: We recently purchased a Howard Miller Grandfather
Just taking a stab that someone replaced the suspension spring with one that is too long, and beyond the pendulum adjustment.
Posted on Oct 25, 2010
male_28_cam
  • 1555 Answers
SOURCE: we have a seth thomas
1, Wind the clock. If the pendulum still does not swing, check the hands of the clock. If the hands are touching each other, push the hour hand gently toward the clock face. If the hands still touch, gently bend the minute hand away from the clock face.
2. Examine the swing of the pendulum. If it moves, and then stops, or if it swings erratically, the clock is probably off-balance. Gently tilt the clock to one side and restart the pendulum.
Watch the swing of the pendulum. If it stops again or continues to swing erratically, try tilting the clock in the opposite direction. Tilt the clock at various angles, on each side, and front and back, until the pendulum runs smoothly and regularly.
Note the clock position in which the pendulum swings freely. Place a wedge underneath the clock in the place needed to maintain this angle. If a wedge alone will not hold the Seth Thomas grandfather clock in the proper position, try lifting the clock slightly up against the wall.
Use a screwdriver to attach a bracket to the wall at the appropriate position. Additional brackets may be needed depending on the angle required. It may also be necessary to employ a combination of wedges and brackets.
Posted on May 28, 2011
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    I purchased a Howard Miller grandfather clock and its keeping time but the pendulum is barely moving. What vould be the problem?
    If the clock has a real clockspring mechanism ( with dozens of visible gears), then the problem is likely it needs to be cleaned.and adjusted.
    Just bought a Howard Miller 620-160 wall clock. The pendulum is not swinging! What is wrong?
    First thing to check is for locks that are put in when shipping so that it wont be damaged. If it is battery powered, check the battery.
    Apr 02, 2016 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    How do you determine what side of the chain that the weight goes on to affect which way the clock turns - at this time the chain is completely off the wheel - clock was recently packed and moved cross...
    R/
    David
    Feb 25, 2010 | Watches
    May 02, 2009 | Watches
    Watches Logo
    343 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
