Question about Sony Handycam DCR-VX2000E Mini DV Digital Camcorder
How to find a driver for my sony dcr vx2000e. I am using a firewire 4 pin to usb, my camera installs but then the laptop tells me it is not recognised. Can yu help with a solution.
5 Suggested Answers
JacvalTrayds
  • 11 Answers
SOURCE: FireWire i.Link which cable?
teedoff1980,
You can buy the FireWire kit at your local electronics store or department. Some kits come with a FireWire cable with USB connectors, as well as "ends" for that cable that come in both 4 and 6-pin configurations. Make sure you ask the store rep and read the package to ensure you have the right ends. You can also buy cables that are already appropriately "ended".
Most cables are 6 pin and connect to the 4 pin port (with a 4 pin end)
Hope this helps :)
Posted on Jan 08, 2008
  • 7 Answers
SOURCE: Sony Handycam DCR-HC28
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to youtube.com
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg. pricegrabber.com)
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to youtube.com. there are some guides on their website as well (eg. youtube.com)
I hope that helps.
Posted on Aug 22, 2008
alfredo_krau
  • 62 Answers
SOURCE: Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Posted on Sep 10, 2009
  • 85 Answers
SOURCE: iMovie 09 / Mac OS X will not recognise Sony
mac doesn't support usb streaming so that leaves us with firewire. it should be a plug-and-play connection. no need to install any kind of driver for the camcorder (but try to check if there are any available driver updates for the firewire card).if possible try to check if your computer firewire port is working by using other devices.your imovie software should detect the camcorder once connected.if not, disconnect cam, open imovie, and connect again.if still doesnt,RESET camcorder.if still the same try restarting computer with cam connected and powered on.check if you have a dv in indicator on your screen.check if firewire cable connection is secured.try diff ilink cable if available.if still no go, try a diff computer. if everything fails might also be a service issue.hope this helps.tnx:)
Posted on Apr 17, 2010
I can not download sony DCR-HC54E mini DV to PC, please assist me in details.
You require a firewire cable to connect to the PC then use Movie Maker to capture the footage.
Cameras use a 4 pin socket and computers can use 4, 6, or 9 pin sockets.
Determine which socket is on the trget computer and buy the necessary cable.
FYI: Most Laptops use 4 pin and most Desktops use 6 pin. Avoid adapters if possible.
For example; if your Desktop computer has a 6 pin socket you buy a 4 to 6 pin firewire cable. Firewire is also called iLink or IEEE 1394.
Feb 23, 2011 | Sony DCR-HC54E Mini DV Camcorder
I want to download material from my Sony DCR-TRV17E MiniDV camcorder to my Windows 7 laptop. Can you help with connectivity issues please?
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Windows 7 compatibility- Sony say it is compatible, but "Windows 7 needs to be preinstalled at the factory" (meaning installed on the computer) rather than an Update to Vista or XP performed by the user. You must also use i.Link, not USB.
Jan 22, 2011 | Sony Handycam DCR-TRV17E Mini DV Digital...
I'm not able to install drivers for my sony mini DV DCR-TRV22E handycam on mac os.
The DCR-TRV22E Camcorder can be connected to the Macintosh Computer with the i.LINK (Firewire) cable. The Software supplied with the Camcorder is not compatible with the Macintosh Computer. Instead you've to use the Firewire cable for connecting the Camcorder to the Computer. You can use the iMovie Software for transferring the videos. You do not require any drivers from Sony, to transfer the video via i.LINK.
You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
Thanks for using FixYa.
We wish you a happy Christmas and NewYear!!
Dec 23, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
Imac 9pin firewire port does not recognize my Sony DCR-HC52
Perhaps a USB to Firewire dongle will help sort you out. As you have discovered those two are not compatible. To make it work, you MUST get a 4 pin card and install it, or the USB solution.
Mar 14, 2010 | Video Cameras
PC with Windows XP will not recognize DCR-HC96 Handycam, and I don't have the software disk that came with the camera. Help
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Windows XP Operating System only):
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
As you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video. The i.LINK port is also called IEEE 1394 or Firewire port.
An i.LINK is a black D shaped connector with 4 or 6 pins. The i.LINK cable is an optional accessory for the Camcorder. You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your Computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Good Luck!!!!!!!!!!!!
Sep 29, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I need drivers for DCR TRV19. I have Vista on my laptop. thx
ThisCamcorder does not support USB streaming with the VISTA OperatingSystem. Use an i.LINK cable to transfer the video to the Computer. Thei.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is ablack D shaped connector with 4 or 6 pins. The type of cable to be usedwill depend on the i.LINK port of your Computer. The Sony Camcorderwill have the 4 pin i.LINK cable and if the computer has the 6 pini.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:As the Camcorder does not support USB streaming with Vista, it is notrequired to use any Sony Device Driver to transfer the video to theComputer. You do not require any Drivers or Software from Sony totransfer the video from the Camcorder to the Computer using thei.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!
Sep 14, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
UNABLE TO TRANSFER VIDEO FROM SONY HANDYCAM DCR TRV TO MY LAPTOP
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 11, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Transfer video to computer
I would like to know more about this USB adapter cable you bought. The camera has a IEEE-1394 (commonly refered to as Firewire or i-Link) connection that is inherently incompatible with USB. I don't see how one cable could do the trick unless it had some kind of conversion hardware built into it. Does it have a little box on the cable or is it just a straight cable?
CNet.com says that your laptop has a four pin Firewire port on it. I would go to BestBuy and tell them you need a Firewire cable with a four pin connector on both ends. If they give you a weird look tell them that is the small Firewire plug, not the big one. If they are still confused, get somebody else to help you. Then use that cable to plug your camera into your computer. Windows should recogonize it automatically. If it doesn't there may be a problem with you camera.
Jan 13, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony DCR-TRV8 video transfer problems
The USB drive for Sony CAM you can download from Sony web but the USB will not allow you to transfer video from your CAM only for memory stick
However if you have firewire input on your Laptop, have you? normaly if you have firewire input on your laptop as soon as you connect your CAM it will detect automatic either with windown movies maker or with Nero
Sometime the firewire from CAM defect I repaired a few of them with this problem
Can you conect this CAM to another computer or try different cable ?
Or tell me exactly what input you have on your laptop such firewire input, PCMCIA slot
Cheers
Dec 04, 2008 | Sony Handycam DCR-TRV8 Mini DV Digital...
Open Questions:
Sony Handycam DCR-VX2000E Mini DV Digital Camcorder Logo
235 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
