Question about Video Game Consoles & Games
Red lights in console ring flashing (2 left lights & bottom right)
  • 43 Answers
Im guessing this is an xbox.....which leads me to beleive what we like to call the "3 red ring of death" which is not good.
there is no easy homemade fix to this problem better get on the phone with microsoft and get started on sending yours back unless you have a warrenty with the store you bought it from.
Posted on May 29, 2008
3 red light flashes. left top. left bottom and right bottom. Problem occurs when power is turned on. Read manual and contacted you.
You've got the three red rings.
They light up when there is a general hardware failure in your Xbox.
If your xbox is under 3 years old, contact Microsoft and they'll service it.
If it's over 3 years old, wrap it in a towel, turn it on and let it run.
This is a simple, yet effective temporary fix.
Mar 09, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
First it wasn't reading disk at all but there was no red lights now the tray won't open and there is 3 red lights blinking 2 on left one on bottom right
you have the red ring of death this is a bug in the system. you should call microsoft support and tell them your xbox 360 has the red ring of death and ask them if there's anything you can do to fix it or if you should send it to them.
Jan 02, 2010 | Microsoft Xbox 360 Console
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
The bottom right red light is on when i turn my xbox on, what does this mean?
it is similar to the red ring of death on the 360 and it means that it overheated and damaged itself
Nov 23, 2009 | Microsoft Xbox Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
2 red lights w/green light
The problem is the black screws on the bottom of the frame that screw into the X-Clamps. Most of the time, you usually don't have to even put the black screws back in. However their can be exscruciating headache inducing problems with fine tuning the black screws. If you do end up needing to put the black screws back in, I suggest to start with one @ a time, starting with the bottom right screw. ( thats with the 360 standing vertical with the dvd drive faced toward U.) The tightness can range from almost as tight as you can possibly get to soooo!!!!!! loose u can't possibly imagine how its doing anything at all. The best way to do this is, with the 360 hooked up, (and the case left off) take the small white plastic frame off that covers the power button, start with the screw loosened and then proceed to turn slightly like an 1/8th of a turn, then power on and then turn off if 2 red or 3 red ring proceeds and then repeat. You shouldn't have to put all the black screws back in, mine only has bottom right bottom left and top left, and are incredibly loose. My friend however has bottom right only and is tightened only about 1/2 way.
Sep 21, 2008 | Microsoft Xbox 360 Console
1 redlight flashes clearly red at bottom right hand side of the power ring,and 2 other dim red lights are flashing,only the 1 in the bottom right is bright though.it happened 2weeks ago but i tryed it...
Do you get an error message on your tv screen? 1 flashing red light means there is a hardware failure such as your DVD drive hard drive, dashboard error ect. Not much can be done about this issue besides having microsoft fix it.
Apr 23, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
