Question about Ovens
Need to replace oven element in Chef stove model EUC5110W- would like instruction manual on how to remove element from oven and replace new element
4 Suggested Answers
  • 27 Answers
SOURCE: Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Posted on Nov 01, 2007
  • 217 Answers
SOURCE: f3, f1 error mesage on magic chef stove, oven not working
http://www.applianceblog.com/mainforums/showthread.php?t=7643 click this link
Posted on Nov 30, 2008
  • 6 Answers
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Posted on Sep 13, 2009
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Shacklock chef manual
Usually (with oven unplugged) the burner will tilt up and is held in by a screw or 2 and has 2 wires attached (normally push on terminals). Have you read these with an ohmmeter to see if they are bad? The oven elements need the back cover removed and you will see the element connection and maybe a screw (if the screw isn't on the inside). It too should be checked for continuity before buying new ones.
Dec 06, 2013 | Ovens
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
Broken oven switch, Magic Chef gas oven
http://panjiva.com/Manufacturers-Of?q=magic+chef+spare+parts
http://www.partselect.com/Magic-Chef-Parts.htm
It;s a global economy now, and you can order and buy spare parts from anywhere for anything. please use these links provided to source your part,and ship it back to the mother land, Aoteroa.
  1. Find the model number on the appliance to be repaired. Look for a gray or silver label on the appliance that lists the model number and serial number. If you cannot find the tag, check the locater featured on PartSelect.com. Click the link marked "Need help finding the model number on your magic chef appliance?" Then click on the type of appliance. The guide will show possible locations for the identification label, along with a sample label for visual reference. The URL is listed in the resources section below.
  2. Use the part number to make ordering simple. Look closely at the part you intend to replace. A part number will be printed or inscribed on any part that is large enough to display at least six digits.
  3. Order parts from appliance retailers. Call local USA appliance shops and ask if they sell parts. If so, get a price quote for your part and ask if it's in stock, or how soon it could arrive.
  4. Order from online parts dealers. Use your appliance model number and part description or part number to check online parts dealers for prices and ship times. PartSelect.com, RepairClinic.com and AppliancePartsPros.com all sell Magic Chef parts online. The Magic Chef website may also be able to provide needed parts. It also lists owners manuals, warranty information and installation instructions for their appliances (see Resources).
  5. Compare prices and order fulfillment times between local retailers and online dealers. Most online dealers will offer lower prices. A local dealer may have to wait for your part to ship from their supplier. The shipping time between local and online dealers may not vary.
Apr 27, 2010 | Magic Chef 9122 Gas Single Oven
What is age span of stove?
I was using a 1938 model in an apartment unit and only replace it for the looks. Electric heating elements are cheap and relitively reliable..
Jan 02, 2009 | Magic Chef Ovens
We have a frigidaire stove. The bottom element has broken in two. We have purchased the new element but cannot locate our manual to show us how to install the new element. Can you give us instructions?
Hello the first thing you do is unplug the stove before doing anything ,open the oven door remove 2 screws holding the element to the back wall pull element forward remove wires with insulated pliers attached to the element ,reattach wires to new element resecure to back wall and test. good luck
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
MAGIC CHEF TIME SAVOR GLASS TOP
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Thanks.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
