Question about Frigidaire Dishwashers
My dishwasher 4000 series Model #PLD4375RFC3 isn't working right, when it starts the water runs in than I hear a click like it's trying to start then it doesn't. The timer just keeps counting down it doesn't wash a thing... in order to get the water out I switch to rinse only and it drains the water. What's wrong with it serial # TH91579830.
  • 209 Answers
SOURCE: Dishwasher just draines and nothing else??
this sounds like it could be the heater element has gone faulty, it is quite difficult to get to test it with it being built in, but basically gain access to the underneath of the appliance and you can test it with a test meter for open circuit, it is also possible that a wire has either come off or broken, the pump pumping out is like a safety mechanism, the eco wash may work because this uses no heat? (some models) the answer i have given you is based on the info you have supplied if i have helped please rate me, thank you, please work safe unplug when working on appliances
Posted on Sep 22, 2007
bigg t
  • 640 Answers
SOURCE: idesit dishwasher
it sounds like the element isnt working properly.locate the element connections by removing the lower kick panel and turn the unit on to the drying cycle.use a volt meter and check the voltage.if you have voltage there than turn the circuit breaker off remove the wires to the element and check with the meter for continuity,let me know.
Posted on Nov 11, 2007
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
  • 7 Answers
SOURCE: Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Posted on Jan 21, 2009
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Dishwasher will not drain
I had a similer issue with my kitchenaid dishwasher , turned out that the water inlet valve was starting to go, allowing to much water into tub at times , so drain cycle would not remove it all. . There is a diaphragm in the water inlet valve that is operated by a solinoid that you can check, but you would have to remove it an test it. Hope this helps
Feb 27, 2017 | Frigidaire 24 in. GLD2250RD Stainless...
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
Maytag 300 series dishwasher: will not wash
Try pouring water from the front and run the m/c. If Ok ,check. Just 12 litrs enough.
1. water inlet flow.
2. water filter in the machine entry point
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Jan 21, 2009 | Dishwashers
Dishwasher
A few things to check:
- is the timer running? The first thing the timer does is open the water valve solenoid. You should hear a click immediately before the water flows through the pipe. If you don't hear this click, then either the dishwasher has no power (check your circuit breaker), the timer is faulty, or the solenoid is faulty.
- is the water turned on? Obvious question, but I have to ask.
- is the hose kinked somewhere?
You didn't mention if the rest of the functions work after the fill function. If so, it must be either the solenoid or a water delivery problem. If not, perhaps the dishwasher has no power, or else it is probably the timer.
Sep 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
