Question about Garmin Rino 110 Handheld Gps Navigator With Built In Gmrs/Frs Radio
My Rino 110 radio gps works fine on Car power, while on the AA battery only, it does not power up and gets very warm.!!!!!!
  • 734 Answers
Hi There!
Your unit has a curcuit which has been damaged and is impedeing the power from the batteryto the main operational curcuitry to the instrument.. PLEASE have it looked at right away by a qualified Garmin Service Center so you can avoid a fire or other unpleasantness.
Kindest Regards
TheSelkie
Posted on Oct 07, 2010
Dc011 radio works with battery but wont work when plugged in what could it be
Sounds like the mains transformer has gone. That is what reduces the mains outlet power of 110 volt to that of the batteries.
You could check the power cord though for 110 volts at the end.
Oct 31, 2015 | Dewalt DC011 AM/FM Radio
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
May 02, 2014 | Garmin Rino 655T Topo Gps 2-Way Radio
I've got a pair of Garmin Rino 110 that we use when outdoors. Recently, with full batteries and clear skies in the desert, not surrounded by trees, mountains, buildings, etc... both of the Rino 110s...
  • That RINO should have no issues picking up satellite signals in the conditions you were in. If you were inside a building I may buy it but not in an open desert. Sounds like they are feeding you a line to me. I might try to get my money back on that one. One thing is for sure, you were in about the best conditions for using that unit. If it failed you then, it will more than likely fail you when your life may rely on it. It would seem that a different GPS/GMRS unit will be necessary to give you that security.
Regards, Tony
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
My rino 110 will not stay on in cold weather, it will turn on but then turn right back off again. What can be done?
Batteries do not fuction well in cold weather. Use a better battery like the lithum or warm up the battery by rubbing back and forth on your pants both sides pos and neg.
-david
Nov 07, 2010 | Garmin Rino 110 GPS Receiver
Rino 110 will not aquire satilite signals.
To have a signal you have to go out in an apartment may not work
Apr 03, 2010 | Garmin Rino 110 (14 Channels) 2-Way Radio
Power Switch will not turn my Rhino 530 HCx on
When I try to turn it on it comes up with the “rino” initialization screen and buzzes/vibrates at 5 second intervals. It never goes past this screen. Occasionally, for about 1 second a small white bar will appear across the bottom saying “0%. I’ve recharged the Li battery and got the same result. I’ve tried it while connected to the charger. Same result. I’ve tried using the optional 4 AA battery pack with fresh alkaline batteries. Same result. Did the factory reboot (page/enter/power buttons). Same – except instead of a buzz/vibrate I get the tone every 5 seconds. Have to remove battery to turn off.
Contacted Garmin tech support today (10/22) - hope to hear from them soon.
Sep 09, 2009 | Garmin Rino 530 GPS Receiver
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Rino 110 stuck in one mode
There was a change to the WAAS satelite protocols. There is a new software download to fix the problem. The link is: http://www8.garmin.com/software/WebUpdater_241.exe
Jun 09, 2008 | Garmin Rino 110 (14 Channels) 2-Way Radio
Batteries in my Rino 120 don't last very long
I believe its 3AA's and it SHOULD last 15 hrs of life. You should probably check the terminal heads and clean them real good you might be shorting somewhere in the connection.
Aug 02, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 110 Handheld Gps Navigator With Built In Gmrs/Frs Radio Logo
27 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
