Question about Printek FormsPro 4500 Matrix Printer
Bad gap home how to fix it - Printek FormsPro 4500 Matrix Printer
2 Suggested Answers
SOURCE: Mp: bad gap home
Bad GAP HOME is a problem with the sensor (switch) that senses the automatically set printhead gap. Usually the wires break from flexing that run to the switch. Could be a bad switch also, or others.
You need to test the switch and wires with a meter.
Posted on Feb 20, 2008
I have a 2005 Yamaha majesty 400, I can't get it to go past 50 mph. I change out the air and crankshaft filter, put in new rollers and V belt, put in new spark plug and it still runs the same. Help!!!
Tappets may need adjusting, carb could need cleaning, maybe a bad fuel pump. You don't say what mileage is up on it, was the camchain changed recently?
If you're a home mechanic, I'd check the gap on the tappets first, it's the least expensive fix.
Jun 03, 2015 | Yamaha Motorcycles
1989 chevy silverado spark plug gap?5.7 k1500
Always use stock type plugs,that what there called for,some vehicles like yours don't run good on other types.They come set at factory,I always check gap and they are always right.As they say,it ain't broke don't fix it.
Mar 22, 2013 | 1989 Chevrolet K1500
Have a 1999 gmc small suv truck that will not start-up after checking the timeing and replace rotor and cap also spark plugs with .060 gap.
> Microsoft Windows XP Home with SP2 ...
Backup all your files & music & E-mail & contacts to an external device: DVD-writable, USB memory-stick, external disk-drive.
Reinstall Windows, and reload your files.
That should fix any SOFTWARE problems -- if you have a HARDWARE problem (dying disk-drive, bad RAM, et cetera)
that's a separate round of trouble-shooting.
Oct 16, 2010 | Microsoft Windows XP Home with SP2...
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
Sunroof air gap and water leak
What you may try to do is place some weatherstrip around which you can find in HOME DEPOT...i can tell you thats the cheapest way to fix your problem.
Mar 03, 2009 | 1993 Toyota Tercel
Printek 4300
Sounds like a bad gap switch. You can order a fresh one at allprintersupply.com.
Jan 10, 2008 | Printek FormsPro 4500 Matrix Printer
Mp: bad gap home
Jan 03, 2008 | Printek FormsPro 4500 Matrix Printer
Printek FormsPro 4500 Matrix Printer Logo
42 people viewed this question
Top Printek Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Printek Office Equipment and Supply Expert? Answer questions, earn points and help others
