Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
My personal pc has not sound coming in attach speaker and earphone
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Oct 15, 2010
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
My sony vaio vpceb24en e series is having a speaker problem, the speaker is not playing any sound in the normal case but if we plug in to earphones it functions smoothly
Buy some contact cleaner and flush the ear plug, and push the head phone jack in and out a few times, and repeat 2 or 3 times hopefully that will return the sound through the speakers.
Mar 11, 2012 | Sony VAIO Computers & Internet
Sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
Nov 06, 2009 | Juster Computer Speakers
Cannot detect when a jack is plugged in.
check your sound card ,,do u have sound threw the pc speakers.if so bad head phones.or not compatable with your pc.
Oct 09, 2009 | Dell A215 Computer Speakers
How can I hook these speakers to a laptop pc? I have a dell inspiron laptop with an output for the earplugs. I was wondering if the ADA995 could be attached to a mocked-up plug for this output. Seems these...
External speakers can be connected to the earphone jack,BUT remember the computer output is only designed to power earphones not big speakers. The speakers have to have an amp built in, like some desktop speakers. Also if you use an adapter to connect the speakers, you MUST make sure the grounds and output wires are matched correctly or you will fry the computers audio board or worse.
Sep 01, 2009 | Altec Lansing ADA995 Speaker
In my c700 the prblem is with audio system. when earphones are fixed to laptop the sound comes from earphone and normal speakers both.tell me what to do?
go to the windows start button - control panel - sound.
Then take a look a the settings, with the earphones plugged in and out.
Maybe, you have to deactivate the normal sound system, while the earphones are plugged in.
Or maybe you see some settings there to control the outgoing sound.
Jun 12, 2009 | Compaq Presario 700 470024-192 Notebook
No sound from speakers or earphones
hi dear
may be problem is that sound driver is not install in your laptop pc so plz install sound driver properly then your problem is solve.
thanks
amit
Apr 28, 2009 | Acer Aspire 5610-4648 Notebook
One speaker/earphone doesn't work on my pc
Are you plugging them into the back? If so, check the audio headers on your motherboard. They'll look something like this:
o o
o o <--- Make sure there is a jumper here
o o
o o <--- And make sure there is a jumper here
o
Jul 07, 2008 | Computers & Internet
-mate JAM Pocket PC Problem
Try putting in earphones and check. Sometimes the contact inside the earphone jack jams against each other and then the phone thinks there are earphones plugged in thus bypassing the speaker.
Oct 27, 2007 | i-mate JAM Pocket PC
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
