Question about Car Audio & Video
Onix an 8006 car sterio the wireing diagram says( yellow to memory b) (black to gnd b) and( red to power b)..Question what does the b stand for. and what is the memory (yellow wire) connected to... Help thanks Terry
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
mixmaster
  • 626 Answers
SOURCE: wiring car sterio
Could not find your specific model.
But I found this on the Sony website.
9-pin wiring harness
16-pin wiring harness
Posted on Nov 25, 2007
  • 14 Answers
SOURCE: need wiring diagram
This is a general wiring diagram for most head units.
Should be what you're looking for.
Posted on Dec 17, 2008
  • 33 Answers
SOURCE: Yellow Wire has no power
Your stock radio should have had a wire that does this. It may not be yellow so look up the wiring diagrams for your car. If you can't find it by doing that, then look up a diagram of your use box. Sometimes there's a diagram on the back of the fuse panel cover or somewhere around there that tells you what fuses are from what. You can then run a new wire if you have to.
Posted on Jan 08, 2009
  • 74 Answers
SOURCE: Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Posted on Apr 18, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
How to connect power wires of JVC KS-RT 404 car radio that we want to install in our caravan
Red is Common hot
Blue is power antenna
Yellow is stand By
Black is ground Radio and Car should Be SaMe ColorsBlue is not Nessicary uunless You hare Power antenna Yellow keeps Time and Channel memory Red Black is a must
Dec 16, 2014 | Cars & Trucks
I need a circuit diagram for a 2000 Hyundai accent sterio plug. ie colours for speaker wires, power, ign, dash lights etc.
speaker wires you can connect one at a time to see which is which as for the others black is earth, red is usually ignition, yellow is constant power (memory) and sometimes you'll have a blue wire for power out or you can usually just buy an adaptor plug to suit most stereos
May 18, 2010 | 2000 Hyundai Accent
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Sep 04, 2009 | Clarion DB148R CD Player
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
4-wire surveillance camera wiring diagram
Cut wires Blue whight yellow orange wires go to what on a security camera
Jun 20, 2009 | Home Security
Can i get wiring diagram of sterio for Acura Rsx 2004?
Generally there are two types of wires , power , and sound. The power wires will usually be black , red , and yellow or orange. Might also have a blue one. Black is ground , Red is constant power , yellow or orange is accessory power ( only energized when key turned on) .
If you have a blue wire , it sends out power when stereo is on , to power an electric antenna or turn on an external amp. All other wires will be in colored pairs. For example Green and Green with a black stripe , Grey , and Grey with a black stripe , purple and purple with a black stripe.......These are all speaker wires , the solid color one is the + and the one with the stripe is the - , EG: Grey might be right front + , and Grey with black stripe would be right front -
May 03, 2009 | 2003 Acura RSX
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Nov 30, 2007 | Clarion DRX5575
Car Audio & Video Logo
193 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
