Question about Brother IntelliFax-2820 Laser Fax
Phone line goes to fax, then ans mach...now caller ID won't work.
I've just bought a Brother 2820 Intellifax. Per instructions, my phone wire goes into the fax, and then an output line goes on to my phone/answering machine. A phone call is answered by the machine, while an incoming fax is auto detected by the fax and begins printing. The only problem is that now the caller ID on my phone won't work. The phone and answering machine are an integrated unit. Are their solutions, shor of buying a new type of answering machine? Thank you.
  • kfetty Jun 14, 2008
    I have a Brother fax 4100e and just realized caller ID is not working.  I can print a fax report and see all the caller ID calls that came in (not as faxes - as calls).  I called Verizon and they said it's the equipment.  I'm already using the setting that this post suggests which is TAD (fax and fax/tel). Until I figure this out, I'm going to use the manual setting because I use the fax machine rarely.  More ideas would be appreciated.  Could # of rings matter or anything else?
    New Friend:
  • 120 Answers
Set the reception mode to Fax with answer machine TAD. Make sure its set for fax with answer machine.
Posted on Jun 03, 2008
My brother fax 2820 gets an NG for about 1 of
I would suspect a DSL or some other kind of DIGITAL phone system.
ALL fax machines are ANALOG devices.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax-2820
may be you have a phone line problem
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Can only recieve some faxes
this sounds like may be there is a phone line problem on those two machines or that line is there dial tone??may be you need to have local phone company check this out
Dec 31, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Jun 29, 2008 | Brother IntelliFax-2820 Laser Fax
Caller ID on EXT phone
First device on the phone line will read hold and confirm receipt of caller ID, there is no data passed to secondary devices.
This is not a fault, this is system standard
Jun 28, 2008 | Brother IntelliFax-2820 Laser Fax
Manual Doesn't Work Either!
Fax machines usually don't have Caller ID. If you see the phone number on received faxes its because the sender has programmed it into their fax machine.
Jun 16, 2008 | Brother IntelliFax-2820 Laser Fax
How do you reset the phone number I am faxing from?
Go into the function or set up under caller name and ID. adjust with keys and press set. Lawrence
Apr 01, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
