Question about HP Compaq Presario V2000 Notebook
My laptop monitor flickers
I bought the laptop for my father 3 years ago but it developed the flickering problem one year after. The flickering became unbearable one time but later sent to a repair shop which seemed to have fixed problem. According to them, a cable was loose.
Then, the problem returned. The flickering is serious when the machine is turned on but it gradually disappears after awhile. I can complete get rid of the flickering if I turn off the graphics card driver but then the laptop can't go to standby mode or hibernation.
I opened up the laptop down to the point where I have to unplug the cable from monitor to the motherboard, at which point I stopped because this is only cable I see and it was pretty fit.
The laptop runs on XP without most uptodate drivers that I can found at hp support website and even graphics card vendor (I believe it is Intel). I flash BIOS with most current version.
I basically did every damn thing I can think of. It is embarrassing for me to ask for help considering I work with software professionally but. I am basically ran out of ideas.
  • 1 more comment
  • hateCompaq May 31, 2008
    thanks for the help. I checked the laptop again today and it appears that it is not related to the lcd itself because if I do not use the graphics card, then flickering stops.
    so I guess this is not particularly comforting because graphics card is on the motherboard it seems and I wonder if there is any way to repair it using some kind of software. Replacing motherboard is not cost effective for me.
    thanks,
  • elmaskbron Oct 05, 2008
    My Toshiba Satellite Laptop M35-S359 is Flickering, lines & turn red please I need some help
  • Anonymous Dec 28, 2008
    I have a Compaq Presario 2100 laptop. I have to admit it’s been a great pc for years. Recently, the screen has begun to flicker black and at times remain black. This problem is very inconsistent in nature. Sometimes it will go weeks without occurring and then return unexpectedly. I have not been able to find a common reason that triggers it. Any help is greatly appreciated.
    Scholar:
  • 110 Answers
Don't worry about embarrassment, there's a world of difference between software and hardware.
The flickering is most likely either a loose wire or more likely a partially snapped dry solder joint where the florescent panel behind the screen is connected. Since the laptop lid is opened and closed frequently, even the smallest of movements over several years can stress a dry solder joint to the point where it cracks.
Unfortunately it's not a user serviceable thing, but you may not need to return it to HP - a local specialist in flatscreens or more ideally monitors is likely to be able to mend it. Since it's so far out of warranty anyway it's not too much of a risk to use someone not HP approved since they can't invalidate a warranty that's long expired, so get your local phonebook out and start searching for someone who can give you a quote on a flatscreen backlight repair.
Posted on May 29, 2008
Maybe you can help me out with a problem I am having with our monitor. It?s an HP 2159m LCD monitor?.we just bought it last year. A couple weeks ago, I turned our computer on (it?s a desktop)?.and the...
Please check the video connections to make sure they are secure.
Some devices have the connections hanging straight down, and gravity works all over the planet.
If you have another monitor available, plug it in and check the computer's video output with it. If you get a picture with the alternate monitor, then you know the original monitor was the culprit.
It really does sound like a loose connection, but would not be surprised, you past the one year mark... that is when warranties expire.
good luck and don't forget to vote!!!
Sep 28, 2010 | HP 2159M Monitor
Screen flickers
i know asus have 2 year warranty ,u can take to warranty
Jan 16, 2010 | ASUS G50V-A1 Notebook
FLICKERING AT THE BOTTOM OF LCD SCREEN
On a 3 month old laptop don't even bother finding out why just get it back to get fixed under warranty. The flickering can be from several things but unless it has been damaged there is no way you should have any problems even small ones with that new a laptop.
The flickering can be a bad connector or power problem which you might see on a 3-5 year old tired laptop but definitely not acceptable on a new one.
Sep 26, 2009 | Gateway NX560X Notebook
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Flickering on any channel
I spoke to Hp tonight and was told that it is the ysus board, hope this helps. Ebay for 175
Jan 04, 2009 | HP PL4260N 42 in. Plasma HDTV
Monitor flashing
I have a similar problem with my screen, same one, 15". For a period of two years it would turn black for an instant and resume functioning. Since two weeks it only flashes the picture for an instant and then turns black again. We opened it up to check the wiring but nothing wrong there. We are 99.99% sure that the problem is in the screen itself and has nothing to do with drivers or anything else in the computer.
If you bought it less than 3 years ago and since it is probably a result of faulty construction, it should fall under warranty (by european law).
I am going to take mine to a repairman tomorrow, i will inform you wether the screen can be repaired or not.
Greetings,
Rengenier.
Oct 10, 2007 | LG Flatron L1715S 17" LCD Monitor
Picture flickers
B board plugs in to A board (signal) part # A-1302-209-A...
Let me know.......................T.
Aug 14, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
HP Compaq Presario V2000 Notebook Logo
1,205 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
