Question about Jensen VM9510 Car DVD Player
Jensen uv7i when i took my uv7i out of the my old car and had it installed into my 2004 acura tl it will not read the disc cd or video it will only play the radio
  • 2 more comments
  • KAYO KIMBLE
    KAYO KIMBLE May 31, 2008
    No how do you do that is that inside of the menu settings or is there like a little button i need to press with a pen
  • h4lov909 Aug 16, 2008
    My Phase Linear UV7, did play DVD's, but now it won't. I think I need to re-set the region settings, but don't know how. Can any body help.
    h4lov909@msn.com
  • cardona_gabe Nov 13, 2008
    my jensen uv7i wont play cd/dvd the screen just stays blue and when i close the screen the display says "no disc".... can anyone give me advice?
  • daves69camar Nov 26, 2008
    I have the same problem with mine. I sent it in to get fixed and then put it in a different car and now it wont play dvd or cd sound. the picture will play just no audio. I get audio with the radio just not from a dvd or cd.
  • 59 Answers
Did you try resetting the unit?
Posted on May 29, 2008
Cd displays "err", it will
This happens when the cd player cant read the disc. you may try a few different ones and see if it will start to read them again.
If you was make this, then there is nothing else you can do without being able to do a internal repair on the unit and we dont have that kind of info. You may also try and disconnect it for a few mins and see if it will reset when you plug it back in.
Keep in mind that the cartridge for the cd has bent or is out of adjustment causing the error code. It will not load the cd correctly therefore it won't play.
You only resolution besides replacing the radio would be to find a radio repair shop. They would charge you probably anywhere from $150 to $250 to repair it. You might want to look at after market replacements.
Keep us updated.
Feb 11, 2011 | 2004 Acura TL
I just bought a 2004 Acura TL. Regular gas use?
Some cars actually require higher octane, if the manufacturer suggest higher octane for maximum effenciency your best advised to do so.
Feb 14, 2010 | 2004 Acura TL
Hi there...I downloaded music onto a blank CD and tried to play it in my 2006 Acura TL and it would not play...Is it the CD or the CD player? Thank you.
it is probably the format the music was burned on the cd,,,it could also be the cd player,some are more sensitive to burnt cds,,,
Oct 08, 2009 | 2004 Acura TL
Disc read error on my 2005 acura TL gps
Was the door open when you got the message (easy to do)?
Did you close the door properly?
Did you replace the disc shiny side down?
Aug 26, 2009 | 1999 Acura TL
Bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Jensen VM9510 Car DVD Player
1996 ACURA 2.5 TL CD PLAYER READS ERROR CDPEO.HOW CAN I FIX THIS?
that model is the older cd player so the newer cds are more compersed so the laser well not read it
Jan 24, 2009 | 1996 Acura TL Series
I have 2006 Acura TL V6. How do I change the cabin air filter?
To change cabin air filter on Acura TL firs time you need to open the glove box and then remove the arm that holds the glovebox. Press the 2 sides of the glovebox to take this out like in picture bellow.
acura-tl-2004-2010-cabin-air-filter-location.jpgAcura TL 2004-2010 cabin air filter location
After do this you can see and locate the cabin air filter housing cover.
acura-tl-2004-2010-cabin-air-filter-housing-cover.jpgAcura TL 2004-2010 cabin air filter housing cover
Push the 2 tabs from the filter frame to unhooking from the housing cover. Take the frame out and replace the old cabin air filter with the new one with the air flow indicating arrow pointing down.
acura-tl-2004-2010-reinstal-the-air-cabin-filter.jpgAcura TL 2004-2010 reinstal the air cabin filter
Nov 26, 2008 | 2006 Honda Accord
Navi prb
instead of fill it gas i axcedently fill it with diesel please let me know what to do and by the way i did not use it cause it start shirffing when oi press on the gas
Oct 13, 2008 | 2004 Acura TL
UV7i Jensen Audiovox In Dash DVD
Run a Lens cleaner kit on it. That is one of those Discs with a coth like material that can be lightly soaked with a cleaning fluid. You can get them at WalMart or Game Stop
Nov 29, 2007 | Jensen VM9510 Car DVD Player
Stereo code
push and hold preset buttons #1 and #6 turn the radio on while holding them down .the display will read out 2 sets of numbers post them here and you can get your code https://radio-navicode.acura.com/ If there is anything else I can help you with let me know .
Nov 29, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
Jensen VM9510 Car DVD Player Logo
381 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
