I have an Elite projection TV. It just started cutting out. Then you can let it cool down for a few minutes then it works again for a while intil it cuts out again. What could the problem be.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Losing power
Posted on May 29, 2008
Coby 26" loses sound after a few minutes, any guess why?
Electronics can fail after they warm up. When they cool down again they start working again. The electronics need replacing, on this TV its cheaper to replace the TV.
Dec 15, 2013 | Coby TF-TV2617 26 in. LCD TV
89 f250 460 engine starts but when u drive it it cuts off like not getting fuel then it wont start , but after waiting a few minutes it starts , then cuts off again after a few minutes, is it a fuel...
it sound like the coil get hot it will cut off till it cool down ,it is possible that it is a fuel filter ,it has only one unless someone has added one
Oct 21, 2013 | 1989 Ford F 250
My van cuts off while driving
Your ignition coil may be on it's way out. When they get older they begin to expand excessively with heat and cut out. After it sits for a few minutes it cools down and works again.
Jun 26, 2012 | Pro-Fit Cv 93 00 Chevy Venture 00 Up
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link www.fixya.com/users/bugoy31
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
Says it is overheated and cuts off after only a few minutes.
Have you cleaned the TV? It's recommended that every 6 months you need to clean the TV remove all the dust inside because it can block the air flow and cause the TV to overheat. Please check that first. Also check if the cooling fans are working properly.
Dec 08, 2009 | Philips 50P8341 50" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
