Question about NEC MultiSync LCD2335WXM Monitor
I am looking for NEC MultiSync LCD2335WXM Monitor power supply...
  • 11 Answers
SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Posted on Apr 07, 2007
  • 121 Answers
SOURCE: screen and colors too bright
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
Posted on May 18, 2007
informatica
  • 1114 Answers
SOURCE: mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
  • 40 Answers
SOURCE: monitor power shuts off without warning
You might check the filter capacitor on the power supply and see if it is swelling or shorted.
srich
Posted on May 27, 2008
jerryg50
  • 1689 Answers
SOURCE: Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Posted on Jun 03, 2008
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
NEC Multisync LCD1765: Screen flashes and then mintor turns off with message "No Signal"
Restart your computer.
As soon as it starts the start-up process, keep tapping the F8 key, repeatedly.
When you see the Windows "start-up" menu, select "start in safe mode".
Does your monitor work in this low-resolution (640-by-480 or 800-by-600) mode?
If so, then you had configured Windows to a too-high resolution that the NEC did not support.
Choose 1024-by-768, and click "Apply", to test that the NEC supports this mode.
Try connecting the NEC to some other computer, to see if the NEC itself is the problem.
Mar 28, 2011 | NEC MultiSync LCD1765 17" Flat Panel LCD...
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
NEC MultiSync LCD2060NX does not power up
Not user servicable and with the low prices of new monitors - not worth the cost of the part.
Oct 29, 2009 | NEC MultiSync LCD2060NX (Bezel) 20" LCD...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Blue screen then shuts off
Sounds like WIN 95 blue screen of death 9x is no longer supported or missing or corrupted drivers, reinstall O/S and perform updates, if not you may have internal parts problem have a extra computer ? swap monitors or plug into computer so loang as if its SVGA to SVGA do not swap into a card and drivers for VGA, or lower .
otherwise contact a Certified Electronics Tech or try Best Buy their techs are certified,
Apr 16, 2009 | NEC MultiSync LCD2335WXM (Silver, Gray)...
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Nec lcd1560v+
http://www.necus.com/support/ go down to where it shows drivers and software, choose NEC MultiSync LCD ...
Download the NEC LCD monitor installer and run it, NEC shows your monitor supported by this software. :)
Feb 11, 2008 | Gateway FPD2275W LCD Monitor
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
NEC MultiSync LCD2335WXM Monitor Logo
94 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
