Question about HP Pavilion a800n (PP163AA) PC Desktop
Disk drives Neither my D or E drives are working. I can't even open them manually (with a paperclip) anymore. My computer does not recognize the E drive at all. I tried to open the drive using media player and hitting the eject button there and still nothing happened. Do I have to buy new drives or can this be fixed?
  • Chris Hall May 11, 2010
    try unpluging one to see if the other shows up
    Sergeant:
  • 458 Answers
Check your IDE cable inside that plugs into it. This will be the wide cable. Does it light up? Your power supply could be going bad. Unplug them one at a time and see if they work. Look at the jumpers and make sure the last one on the cable is on Master and the other one is slave. Sounds like a bad cable or connection.
Rate me if this helps.
Posted on May 29, 2008
Disk will not eject
Unplug the drive. insert a paperclip in the hole in the back of the drive. This will manually eject the disk. You can also open the cover but that's a lot more work than you need to go through when a simple paperclip will move the manual eject lever.
Jan 19, 2014 | Iomega Z100P2 External ZIP Drive
My dvd player is not recognized by my computer anymore.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 04, 2012 | Pioneer Bd-rom Dvd±rw Laptop Drive...
My TEAC FD-05PUB is recognized by my computer. However, it will not open a floppy disk. It says the disk needs to be formatted (even thought the disk works fine on other computers with the same operating...
Try a brand new disk put something on it and go from there the disk you may be using may be no good anymore. Try this first before getting another replacement disk I would stop using these floppy and go to a USB Stick for storage purposes since they are going obsolete. Just a suggestion! That would solve your problem using floppies for storage besides they do not hold much information compared to todays storage devices. John
Jan 15, 2011 | Teac FD-05PUB External Floppy Drive
Using Windows Vista on Dell Dimension Desktop: Windows Explorer does not show a DVD drive. The eject-close button does not extend or retract the disk tray. I have opened the tray manually with a...
try method 5 listed on this site:
https://support.microsoft.com/en-us/help/314060/your-cd-or-dvd-drive-is-not-recognized-by-windows-or-other-programs
May 22, 2017 | Dell Dimension E521 PC Desktop
I can get the disk tray open.
Is the drive being recognized in windows? If not at all then it may need to be replaced as it has totally died on you.
On the drive door there will be a pin sized hole. This is the 'emergency' release. You insert a paper clip or a pin and it releases the catch and the door will pop open. Do with with the power OFF. If that won't open the door then it is probably jammed or siezed. At this point you would have to pry it open which can cause damage to the drive if done too roughly. If you have something like a sticker or say two cd's in the drive then once you get it starting to open the trick is to firmly but gently and evenly pull on the sides of the door and then the body. Usually they will fight up to a point then open. When you get it open make sure you find and clear or clean the cause. The next time you have to open it may not go as easy.
If you need to replace the drive that is covered under warrenty or can be purchased third party for about $80 and up for a new drive.
Jul 06, 2010 | Gateway M-6750 PC Notebook
DVD drive doesn't recognize the disc
insert an unfolded paperclip or similar object into the little hole on the front of your cd rom drive to manually open it, insert a cleaning cd. if this doe snot rectify your problem check and original software disk (not a copy) and if its still not being recognised then replace the drive.
Jun 22, 2010 | HP m1170n PC Desktop
Acer laptop Aspire 5535 DVD drive stopped working for no reason
It would seem the drive probably has a mechanical or electronic fault...
You did say it is a new computer. If it is there should be no real problem due to the usual warranty and the responsibility the retailer has for the products they sell. In addition if you paid by credit card you might discover it provides additional protection against faulty goods.
Apr 22, 2017 | Acer Computers & Internet
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Compact Disk Drive isn't opening or recognizing disks
The drive may be dirty or jammed. Use an expanded paper clip. Insert the wire into the little hole on the front of the unit. That will engage a manual switch. Gently open the unit all the way. Now press the button and let it close by itself. If this doesn't work it may also be an electronic failure.
Apr 07, 2009 | Dell Inspiron 6400 Notebook
HP Pavilion a800n (PP163AA) PC Desktop Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
