Question about GE Microwave Ovens
New microwave GE Profile X acts as if it is cooking, timer counts down, but no cooking
  • 1 more comment
  • skierjmk May 30, 2008
    -the inside light does come on
    -the turntable does not run, the option is turned on
    -the fan does run
    -it has never made a cooking sound, the timer does count down as if it was cooking.
  • William Miller
    William Miller May 11, 2010
    When the Start pad is pressed:
    - Does the inside light come on?
    - Is the turntable running?
    - Do you hear the cooling fan running?
    - Is it louder or quieter than before?
  • Anonymous Mar 24, 2014
    where to get new decals for the burner settings
  • GE Master
  • 9,086 Answers
Sounds like a bad door switch or a misaligned door switch mount or door.
Sometimes you can gently push up and down on the handle a tiny bit while it's not running right and et it to try to work.
But since it's new, I would let GE fix it free.
GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 30, 2008
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Timer counts down very fast
The keypad control board will need to be replaced, bare in mind the cost for the part will exceed the price of a new microwave oven in some cases.
Apr 12, 2012 | GE Microwave Ovens
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
Have a GE microwave for three months bought it brand new and wife was making potatoes in it opened door to check on them and then closed door to continue cooking and it continues to count down but light...
The door switches are slightly out of alignment. If you run the microwave and shift the door up or down, the micro might begin working..
The control panel must be removed and the door switches adjusted. I would not suggest you doing this yourself, as it may affect the microwave leakage through the door gap.
Jan 02, 2011 | GE Microwave Ovens
My GE 1660 profile microwave oven will not cook or rotate, but the timer reduces in time. I have tried to gently press up or down on the door in case it is a door latch issue with not change. Also it keeps...
Check the door safety interlock switches. If they are burned (because you frequently open the door while the oven is running) they tell the magnatron that the door is open (forget what you know about the door) and not to run that magnatron (which produces the microwaves that actually heat the contents of your oven).
Check the switches with a ohm meter. Remove the cover to find the switches near the door latches.
Thank you for your interest in FixYa.com
Dec 26, 2009 | GE JE1660 Microwave Oven
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
May 10, 2009 | GE Profile Spacemaker Over-the-Range...
Set control board to cook and not working
you have a bad door switch, check for burns on the switches and connectors, if not its the pc board
Jan 09, 2009 | GE JVM1631 Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
