SOURCE: Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
SOURCE: f61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
SOURCE: f61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
