Question about Skull Candy Full Metal Jacket Stereo Ear Bud Headphones - Silver
FMJ: My left ear bud is louder than my right so my center of pan is offset to the left which is very annoying
SOURCE: Sound very muffled in right ear bud
Yes, more than likely it is the wax build-up inside the screen of the earbuds. Take a tack and lightly pry the screen out. You will definitely see a noticeable amound of "gunk on the inside. Clean and you will hear a clearer and crisper sound. If you put the screens on flush and press them in they will stay.
Posted on Sep 26, 2008
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
sonicboomele
  • 1557 Answers
SOURCE: left ear bud does not work
yes a coil can burn out in secounds i think you have better have the unit looked at by an technition
Posted on Apr 23, 2010
SOURCE: Philips SHE9550 right earphone is louder
Your current solution to solve the difference in volume (the piece of paper) is not far from the problem.
Your problem is earwax. I have the same earphones and had the same trouble. I checked cable and plug but they were all fine. So then I checked for earwax. It didn't look like I had too much on the rubber plugs - removed that. The problem was what was on the nets. There was some visible, I tried my best to remove that with a sharp knife but the problem remained. I tried to remove some more and found that you can remove the nets easily with a sharp item - just pull them upwards.
There was quite some on the inside of the nets. I thoroughly scraped it all off with the same knife. There can very well be better ways to remove it but this worked perfectly for me.
When all was gone, I tried the earphones and was shocked at how much the volume had gone down in both ears (more in one) before the cleaning.
I hope this helps.
Posted on Jun 22, 2010
MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Feb 15, 2017 | Marantz Audio Players & Recorders
How do I fix my ear buds when theirs 4 wires from the jack but only 2 wires to the buds???
Hi.. Could the jack have left wires for the left bud and right wires for the right bud...... Just a thought..
Mar 26, 2016 | Audio Players & Recorders
The sound is weak. The max. Volumn is very weak. How can I get it louder.
In general, tablets don't have powerful sound systems. Some ear-buds will play louder than others, but don't expect any built-in speaker to play loudly. Try different ear-buds, that may help, or an external "amplifier".
Dec 07, 2015 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
The left ear is louder and much clearer than the right ear
Tried the knife, made it 10% better but no wax to clean, bc a small rubber circle is under the net... 3 good hard plucks made mine work again. Don't be afraid to pluck it hard, I tried it before softer, which didn't work initially. Reassemble, twist it's neck counter clockwise (right ear) and pluck HARD.
Feb 11, 2014 | Motorola Mobility S11-HD Bluetooth...
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Half volume in one ear on my fmj headphones, this only happens in he left ear. Its whenever i pull them out of my ear and i put them back in,i tap them and they go back.
the same thing happend to me... this may soud wierd but have they ever shocked you? cuz if they did that means you blew the speaker... these are GREAT headphones but they are poorly built. the speaker is in the wierd looking bump in the headphone and because its in a sealed enclosure and because its 16 ohms you can blow the speaker easily. just return them. skullcandy is really good with returns.
Sep 25, 2010 | Skull Candy Full Metal Jacket Stereo Ear...
Left ear bud does not work
Apr 21, 2010 | Sony Bud Style Headphones
Wire broken near plug. Need disassemble a plug. How
You can buy a new plug and solder the wires to it. Leave a long enough piece of wire on the old plug to test to see which wire goes where. On the plug it should be tip+left, 2nd ring + right and the base or body is ground. Don't forget to put the shield that screws on the plug right way around on the cable before you solder.
Aug 12, 2009 | Skull Candy Full Metal Jacket Stereo Ear...
One speaker is MUCH louder than the other
It sound like you have a break in the main wire from the computer sound card to your speaker amp OR the plug is not plug in completely plugged in all the way. Try some other speakers or ear buds / head phones to isolate sound card problem or speaker problem.
Jul 07, 2009 | Dell A525 Computer Speakers
Skull Candy Full Metal Jacket Stereo Ear Bud Headphones - Silver Logo
277 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Owen Barnes
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
