Question about Dual Electronics BDS692 Coaxial Car Speaker
Stereo issues i have a dual cd player model xd7500 and the face has decided not to open up anymore do you have any suggestions on what to do?
  • 23 Answers
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
Posted on May 29, 2008
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
Need a wiring diagram for this radio
Here is a link to the stereo's owner's manual which will tell you how to hook it up:
May 15, 2010 | Dual XD-7500 CD Player
My dual xd7500 cd player doesnt turn on anymore while hooked up only the power button light turns on nothing else works this is hooked up in my bedroom but the problem should be the same as in car can...
Is the red wire in the back hooked up to a power source? You will need that in order for it to turn on. It is the wire tells the radio to turn on when you turn your key.
Oct 18, 2009 | Dual XD-7500 CD Player
Who do i take off my face on my dual xd7500
when the radio face is open like it is in the picture above... take a look /feel directly underneath (back side of the lower controls)the large center knob. you are going to feel a push button about an inch wide. push while pulling down and toward you to remove. the until will then close on it own. reattach by clipping directly on once unit has closed
Aug 15, 2009 | Dual XD-7500 CD Player
Dual XD7500 Faceplate Problem
the faceplate has a loose or broken contact on one of the wires on the ribbon wire located in back of where the faceplate mount. the ribbon wire is expensive and you must open the radio and install it. the wire is about 30 bucks plus shipping from the dual company or namsung. you can also find the ribbon wire for sale at or
Jul 16, 2009 | Dual XD-7500 CD Player
I am looking to see if i can find or buy a face for my dual xd7500
i do know that ebay has one listed, its the only one i've seen
Jan 30, 2009 | Dual XD-7500 CD Player
you can buy the plug from the like $30.00 plus shipping their number is 1-866-626-7863
Jun 19, 2008 | Dual XD-7500 CD Player
Dual XD7500
there is a corkscrew that opens and closes the face plate, it will get worn down since it made out of plastic, when it wheres down, only have of the screw will have threads, the have of the screw that has threads will let you take the cd in and out, but in order to get the whole face down it needs to use the whold corkscrew, the corkscrew is located on top of the unit, only visible after the top cover is taking off, you'll see it on the right side of the unit, you can try to order one from, its such an easy fix
Jan 27, 2008 | Pioneer DEH-P44 CD Player
Detaching faceplate on dual stereo XD 7500
Got to the following lik for your manual: Refrence page 6 for instructions. With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure. Hope this Helps L8R
Sep 18, 2007 | Dual XD-7500 CD Player
This is what the manual says:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
to remove. To install, insert left side faceplate first, then push
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Dual Electronics BDS692 Coaxial Car Speaker Logo
124 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
