Question about Leupold Rifleman Rifle Scopes BHK290
In the process of zeroing the scope in I noticed that I can adjust the elevation of the scope up but can't set the adjustment down as far as I need to go in order to be sighted in. This is the first time I've noticed the problem and have yet to do anything to fix the problem. Also, this scope is at least 30 years old.
    President:
  • 2,976 Answers
There are a few things that it could be. Make sure you have the scope mounted with the elevation screw on top and the windage screw on the right side. Next, carefully check the distance of the scope from the receiver. If the mounts aren't exactly the same, the scope could be tilted upward. Try switching the front and rear mounts. Make sure you don't have either of the mounts on backwards. Make sure the scope is built for the caliber you are shooting.
If none of these fix your problem, Leupold scopes are guaranteed for life.
Posted on Oct 07, 2010
How to reset bushnell elevation adjustment to zero?
If you want to center the cross hair in the scope
Rotate elevation down to it stops then count up clicks to it stops then half number and rotate down that number then repeat with windage or you could use two v blocks and view a point through the scope and rotate scope and adjust cross hair until no deviation from a fixed point up or down left or right
Hope this helps
Dec 07, 2014 | Bushnell Optics
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
I inadvertantly changed my elevation adsjustment.
this is an excellent article on zeroing a scope.
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Apr 06, 2010 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
Bought a 444 Handi Rifle with a Bushnell 3200 firefly scope on it. Tried to sight it in at 75yds yesterday. I adjusted the elevation up 6 to 8 "inches" and I am not noticing any change. Still shooting low....
O.K Your gun packs a good kick, but you might try to first, tap the scope with the handle of a fair sized screw driver, after each adjustment. Next do not adjust it so many clicks at the time just 3 clicks and see if she moves the point of impact. Try a few clicks and tap the main shaft of the scope kind of rap it then shoot for group, fair 2 rounds to see if it has settled down, then adjust a few, tap and fire. work slow with a older scope and try to stock up on the bullets you decide to go with and zero for them. Any other round you use do not zero, but use go old windage to pratice with.
Oct 26, 2009 | Bushnell Elite 3200 Firefly 3-9x50 Matte...
Unable to zero in on target?
take it in because if he bumped the rail the scope is on it can make it inaccurate
Aug 01, 2009 | Optics
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
Adjusting Range on Redfield Scope
There should be a set screw or screw that you can loosen to make that adjustment. Once you have it where you like it, just tighten it back up and enjoy you ability to make those quick adjustments when needed.
Mar 29, 2009 | Optics
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Leupold Rifleman Rifle Scopes BHK290 Logo
282 people viewed this question
Top Leupold Optics Experts
George Merkley
George Merkley
ray gallant
Are you a Leupold Optic Expert? Answer questions, earn points and help others
