Question about Kicker S12D Car Subwoofer
Need the measurements for a sealed box for a kicker s12d subwoofer
  • 10 Answers
If it's sealed...build it yourself...you can even get home depot or rona to pre cut the 3/4 mdf for you. You need a box that's 1 cube interior volume which is 12x12x12 or 13.5 x 13.5 x 13.5 outside, so you need 6 pieces of mdf, two (13.5x13.5), two (13.5x12), and two (12x12). Don't worry about driver displacement as it's about .08 cubes, so you'll still be at .92 cubes after that, and it will simplify your design. Get some glue, screws, and caulking (or use the glue like i do). Put it together, let it dry, seal it, and then paint, cover, or leave it as is. Cut your 11" hole for your speaker, drill a small hole for your speaker wire (forget terminal caps), run your wire and then seal the hole with caulking, mount your speaker using a gasket or rope caulk, hook it up and enjoy.
Posted on Oct 07, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
Jan 15, 2011 | Kicker Car Audio & Video
Kicker 8 inch l5 problem!
Possibly. Actually there are sub rings you can buy to convert a regular box over to one that will accept a square sub without cutting the whole out in your box to make it square. The airspace may be lacking a little bit.
May 20, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Does the solobarics fit in a mitsubishi diamante in the sealed box it comes in 12 inch
i dont see why not you could probably do 2 in a ported box and make it sound 2 times as better then sealed
Apr 02, 2010 | Kicker Solo-Baric L5 Car Subwoofer
What are the specs on a kicker sub box for a challenger srt8
On a 8 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 11 liters, meaning that you will end up with a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 225mm high, x 225mm wide, x 225mm deep. Seal the box on the inside with silicone for better bass.
Oct 19, 2009 | Kicker Car Audio & Video
I have to force the cone to go in and out
if it is in a sealed box its not suposed to move the more sealed your box is the harder it will be to move the woofer a really good box you wont be albe to move it if you have leaks in the box it will move
Sep 03, 2009 | Kicker C12-4 Car Subwoofer
My car subwoofers work, but theres no bass
turn them off and carefully push in on the cone (gently) and listen for scratching or scraping- push strait in and they should flow freely in and out if they DO without feeling or hearing scraping the subs are probably ok, next its either the amp is not powerful enough or the box is not soundly built, by that i mean its too small for the subs- is the box ported or sealed? if ported try plugging off the vent temporarily and see if bass increases if it does i would permanently seal the box
Mar 13, 2009 | Kicker 06CVX122 12" COMPVX Subwoofer,...
Box size
http://kicker.com/Product_Manuals/93/104 , look at the tech manual, it will give you dimensions of sealed or vented and it will give you a couple of box ideas.
Feb 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Kicker S12D Car Subwoofer Logo
110 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
