Question about Philips Audio Players & Recorders
How do i add pictures to a philips GoGear HDD630. thanks
  • 8,596 Answers
Go into Windows Media Player, click on the musical not icon, and a drop down menu will come up that allows you to select "pictures" instead - sync the pictures just like you would the music. make sure the pcitures are in jpg format, and the size reccomended by the spec sheet. Spec sheet can be found at:
www.usasupport.philips.com
Posted on May 29, 2008
How do you add .gif pics to Philips MP3 GOGEAR sa6045?
GIF files are not supported by this player - you must convert them to JPEG's. Videos have to be run through the Philips (Arcsoft) Media Converter - the software is available from Philips website for free. The link to the user manual is here:
http://www.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GOGEAR SA6045 MP3 Player
How To Add Videos to my gogear mp3 player
Go to www.usasupport.philips.com - download the latest version of the Philips (Arcsoft) Media Converter
Jan 14, 2009 | Philips GOGEAR SA6045 MP3 Player
I don' t know how to insert pictures in Philips GoGear HDD1830 MP3 Player
You must install the CD that came with the player. It contains a critical plug-in that is necessary for picture viewing.
Nov 15, 2008 | Philips GoGear HDD1830 MP3 Player
Philips 4GB GoGear Flash Audio Video Player - Video Error
just download youtube converter it is freeware.add the file ,choose the format i.e avi ,get the output file .now load it on philips media converter it will read and work.
Oct 09, 2008 | Philips GoGear Flash MP3 Player
How do i get the pictures off my gogear?
Connect the device to the PC.
Open My Computer. The GoGear should show as a drive.
Double-click on GoGear, navigate to the Pictures folder and delete the files manually.
To prevent this happening again, go into the Windows Media Player settings, and select manual sync. This varies with different versions of Media Player.
May 02, 2008 | Philips GOGEAR SA6045 MP3 Player
How
IMPORTANT: Do not drag and drop pictures into the GoGear with Windows Media Player or Windows Explorer. Also ONLY JPG/JPEG images are supported.
First check your computer to see if you have the latest version of the Philips Plug-in installed.
  1. Click Start > Control Panel > Add or Remove Program.
  2. Search and select Philips Device Plug-in. Click “Click here for support information” to check the version.
  3. If you already have the latest version (V3.13.00 for HDD6330 or HDD6320) (V3.14.00 for HDD1420, HDD1620, HDD1630, HDD1635 or HDD1830) then there is no need to upgrade.
If you need to upgrade your Philips Plug-in:
  1. Launch Internet Explorer
  2. Go to the Philips support site at http://www.ph ilips.com/support
  3. Select your country & language.
  4. Enter the model number and click on "Search".
  5. Select the model number if there is more than one listed.
  6. Click on Software & drivers on the left-side menu.
  7. Double click the respective language under PC Software to save the exe file on your PC.
  8. Download the file to your Desktop on your PC.
  9. Run the LM_XXX.exe to start the installation.
  10. Follow the screen instructions to complete the installation of Philips device plug-in.
Once you have the latest version of the Philips Plug-in installed, please follow the below steps to transfer your picture(s) onto your GoGear.
  1. Launch Windows Media Player.
  2. Go to File> Help> About Windows Media Player to check if the ve rsion is 10. If not uninstall your existing version of Windows Media Player and install the correct version of Windows Media Player from the installation CD1 or Microsoft's website.
  3. Make sure the Philips Plug-in is installed on your PC. To check whether this Plug-in is available on your computer, go to Start> Control Panel> Add or Remove Programs and check if Philips Device Plug-in is listed. If not, re-install the software from the installation CD2.
  4. Check and make sure that the "Enable picture support for devices" option on Windows Media Player has been selected.
  5. Go to File> Add to library. From the menu, choose to add pictures from folder or by searching your computer. These files will be added to your library.
    Note! Files that are directly under “My pictures” should be saved in a s ub-folder before adding them to your library. If you do not do this they will show up in Windows Media Player with the event name “Unknown” and they will not show on your player.
  6. Click on the Library tab. Go to All Pictures. Click to highlight the item you want to copy. Right click on the item and select Add to> Sync List.
  7. Click on the Sync tab and select "Sync List". Choose Philips as your destination in the device pane.
  8. Click on the "Start Sync" button in the top left corner to start the transfer. Once the images start to synchronize the computer will show:
    051028091952_1761.gif.
    (If you cannot see the above Philips Device Plug-in pop up, your Philips device plug in may not be installed properly. Please uninstall and reinstall Windows Media Player& nbsp;using both installation CD ROMs.)
  9. After the transfer is complete unplug the GoGear from the computer.
  10. You can then view pictures (thumbnail view and full picture view) from the Pictures menu.
Jan 23, 2008 | Philips GoGear HDD1830 MP3 Player
Videos and Pictures in the Music category
NOTE: you only have to follow the process for ending automatic synchronization - repair is optional.
When you first synced your GoGear to Windows Media Player, you may have set up the automatic sync option. When this option is selected,Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the GoGear. Now, every time you sync you device, it adds every new file from your computer into the GoGear automatically.
Here's what you want to do (this process assumes you have Windows Media Plaer 11 and windows XP - if you have another version, just let me know and I will give you modified instructions - reply to the FixYa website, not to my personal e-mail address):
1) Backup all files stored on your GoGear, as this process will delete all files from your GoGear
2) Go into Windows Media Player 11 with your GoGear connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portbale media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding songs/files you don't want into your player
3) As long as the GoGear now says, "OK to disconnect from PC," then open up Philips Device Manager (Start --> All Programs --> Philips)
4) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
5) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is succesfully complete, your GoGear will be good as new
6) you will have to re-add all your files (only the ones you want in there) to the GoGear as the Repair process has deleted all files on the device; as long as you followed the process in Step 2 above, then Windows Media Player will no longer add the files you DON'T want to the GoGear
-Tha Mp3 Doctor
Jan 02, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear: delete music from library & are there any Unicode
Here's what happened: When you first synced your GoGear to Windows Media Player, you may have set up the automatic sync option. When this option is selected,Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the GoGear. Now, every time you sync you device, it adds every new file from your computer into the GoGear automatically.
-Tha Mp3 Doctor
Oct 24, 2007 | Philips HDD1630 MP3 Player
SA 4010 philips mp3 player
Here's what happened: When you first synced your GoGear to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the GoGear. Now, every time you sync you device, it adds every new file from your computer into the GoGear automatically. It will even delete songs from your GoGear that were on there before.
Go into Windows Media Player 11 with your GoGear connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding songs/files you don't want into your player.
-Tha Mp3 Doctor
Jun 13, 2007 | Philips SA4010 MP3 Player
380 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
