Question about Garden
I need a exploded view of a hilti te 52 hammer drill
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 61 Answers
SOURCE: HOW DO YOU DISASSEMBLE THE GEAR BOX SECTION OF A
Its not that hard. however I have been working with hiltis for 22 years. once you have removed the handl assembly, remove the 4 screws which hold the motor unit to the gearbox. you will lose oil but dont worry. this will expose the drive gears. the smaller one is the crank drive or the hammer action. the larger one is the clutch assembly for the drilling action. remove the smaller of the 2 gears from its shaft by removing the circlip. you should now be able to see the circlip which holds the crankshaft into the gear housing. remove the circlip and pull out th crankshaft, this will be a tight fit so you may have to hold the shaft in a vice and carefully fit the gear housing using a rubber mallet. now you have to remove the chuck. 1st remove the rubber cap by getting a large flat screwdrivver behind it. using circlip pliers, remove the c-clip (wear safety goggles) the rest of the chuck parts should them be able to be removed with easy. you should now be able to see a large circlip, remove it. you can now remove the oil seal. this will need replacing as it is hard to remove without damage. part number 206105. under the seal there is another circlip. once this is removed you will be able the remove the guts of the gear box. again you may have to put the chuck tube in a vice and tap the gearbox housing with a rubber mallet. again you will loose oil. to reassembly just reverse the prosess. remove the oil filler cap to ensure that the crank shaft locates on the con rod . once reassembled replace the oil. 40cc only. transmission oil is good and the closest match you will get to the origional. for more info send me an email.
paul@wysehire.gi
www.wysehire.gi.
ps before you start make sure that parts are still available for this machine asit is quit old (no offence).
The piston rings (17955) are but i dont know about the oil seal.
you car get the seal from any car parts shop. it is a double lipped seal 35mm x 62mm x 10mm.
I hope this has helped. please leave feed back.
email me if you want a diagram sent.
Happy xmas
Posted on Dec 13, 2009
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 123 Answers
SOURCE: HILTI TE 72
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Posted on Mar 13, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Replacing brushes on a hilti te 7a 36v cordless hammerdrill
the fan probably exploded and you would need to replace the motor assembly. You can contact HILTI direct at 1-800-879-8000 for parts and breakdowns.
Jan 26, 2012 | Hilti Drills
I need a exploded view of a Hilti TE905AVR
you can go to Hilti.com and download this file after entering your region under downloads it is about halfway down the page. If you have a problem with the download call them direct at 1-800-879-8000 and they can send as a PDF file. Let me know if you need more help
Jan 31, 2011 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
My Hilti Te 52 hammers hard for a minute and then stops. The motor keeps turning, if you lift slightly on the bit it'll start hammering again. After another 20 seconds it'll stop again. You can drill a...
It does sound like the clutch is worn out. You would have to completely disassemble the whole tool just to get to the clutch. Then there are no parts available.
While the 52 was a very good drill the clutch had a tendency to wear out. I know it is hard to give up on a tool that is still working halfway, but the tools made today are much faster than the 52.
PS if you look to purchase a new one from Hilti they always offer a trade on your old one.
Apr 03, 2010 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
I have a hammer drill UH-240A and need motor brushes. Where can I find them?
ive checked the hilti website and theres no brushes avaiable
this is a link to the exploded diagram and parts listing
http://www.us.hilti.com/data/techlib/docs/tool_schematics/sfs/UH_240_A.pdf
it looks as though you would need to replace the motor
heres the link for it
http://www.us.hilti.com/holus/modules/prcat/prca_fuse.jsp?RANGE_OID=31634
hope this helps
if it does please vote
Nov 09, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
