Question about Dishwashers
Manual for heller HDWE 12SS to interpret error code 004
2 Suggested Answers
SOURCE: hi there,we are getting error
I have the HDWE12/SS manual, the following may help, or not!
According to my manual error 4 means it is "overfilled", and the possible cause is "too much inlet water". I doubt that is much help but that's all the manual says.
Error 2 is "longer draining time" with a possible cause of "the installation position of the drain pipe is too high"
Posted on Feb 09, 2009
How do I fix error code 004-332
That error code signifies a developer home position sensor error. Can you move the carousel by hand? It also may be that a toner is leaking and has spilled onto the home position sensor.
Oct 04, 2014 | Xerox DocuPrint C525A Laser Printer
Truck wants to act like it is running out of gas...hesitates and misses outs at slow speed but stops once speed has increased. Has been plugged into a computer box and the mechanic gets no error code for...
Just because it doesn't set DTC'S - diagnostic trouble codes , doesn't mean it can't have a problem with a OBD2 sensors , fuel system problem etc .... Taking the vehicle to a qualified technician that knows how to interpret sensor data an systems data should be done .
004 Fuel System Tests Start Here
003 Engine Peformance Tests Scan Data Tests
Could it be the transmission or fuel pump??? We test ,not guess ! Take it to a qualified repair shop.
Feb 24, 2018 | 2008 Dodge Ram Pickup 1500
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
Dish network error 004
Hi there, Tim!
It's possible the dish may need to be repointed. Try running a check switch test. Go to Menu > System Setup (6) > Installation (1) > Point Dish (1) > Check Switch > Test. This will provide more info on the satellite signal.
If you have run that test and the problem continues I would need to see about getting a tech out. If so, you can send me an email at thomas.faust@dish.com for further assistance!
Tommy Faust
DISH Social Media Representative
Mar 25, 2012 | DISH Network 625 Duo DVR Receiver...
I have just changed the drum cartridge on my DocuPrint C525A printer and i have this message: 004-321 Reboot Printer. I have turned the printer on and off but nothing changes. I looked through the manual...
004-321 is a TR0 error, which means the accumulator belt could not find the beginning of belt mark.
The belt is part of the Drum Cartridge. Replace/Reseat the drum cartridge and reset printer, this should correct the problem
Jun 16, 2011 | Fuji Office Equipment & Supplies
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Hi there,we are getting error code 004 coming up on our dishwasher, make is Heller, model is HDWE 12, as we don't have a manual,thanks
Jun 09, 2008 | Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Dishwashers Logo
137 people viewed this question
Top Dishwashers Experts
