Question about Haier HTF24R21 24" TV
In tv second and third band is not working we are using from the ten year
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
I have a Task Force 10" band saw, model # 90181.
for the tires, I asked in another forum and this is what I found:
fortyfinge user_offline.gif Join Date: Sep 2004 Location: USA Posts: 2 reputation_pos.gif way easier, way cheaper masking tape. Just plain white masking tape. About 8-10 wraps around the circumference of your wheel. I tried this about 15 years ago as a stop gap method while waiting for the new rubber ones I'd ordered to arrive. The new rubber was a pain to install and only lasted a couple of years under daily use.
Jun 13, 2011 | Saws
For several months we would get bands of lines across our screen. We thought we were experiencing some kind of outside interference as it would come and go. Two days ago the bands began to cover most of...
You're verical output IC is dead, this might because of a leaky capacitor on that section which causes the lines across the screen.
The processor shuts down the unit automatically to avoid further damage to your tube.
Send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Jan 18, 2011 | Hitachi Televison & Video
Car is automatic will not engage in reverse
Common problem with EN471B is clutch bands failing. Same band for reverse and second gear. Any second gear problems? Possibly shifting directly from first to third? Drop transmission pan and check for bits of clutch band (non- metallic debris) to confirm.
Mar 17, 2010 | 1986 Nissan 300ZX
Wii drum set doesn't work
if the blue light's are flashing on first,second,third,or fourth light then it means your batteries are low or your drum set is for another game
Jan 28, 2010 | Nintendo Rock Band for Wii
TV resistor mystery
Go to an electronics parts shop and take the damage resistor with you.
The bands are a colour code (the first two bands indicate the first two numbers, the 3rd one is for the number of zeros and the fourth one is the accuracy of the value e.g. 5%, 10%) for the value of the resistor.
The physical size of the component gives an indication of the current that it can carry.
Dec 19, 2009 | Washing Machines
HOW TO PROGRAM A FOBIK KEY FOR 2008 DODGE CHARGER
your car came with 2 fobiks from the factory, if you bought a third one from Chrysler, read on, insert the first one in the win module, (key hole), and turn ignition to on only, watch your sentry red light to come on, wait till it goes out, you have ten seconds to insert the second one, red light will come on and start to blink, you have ten seconds to insert the third one , turn it to on and watch the red light to blink and once it stops and a chime will sound, the third fobik is now programed. If you only have one fobik, lost the other, your out of luck, you will have to visit a Chysler dealer. GOOD LUCK, RDJRP
Jun 03, 2009 | 2005 Dodge Charger
Second input connection does not work
Here is a link for the manual to your TV.
It looks like page 14 says that you must Set the V2 Component In on the initial set up menu to YES for proper display.
Let me know if this is where the problem is! If not, we can continue!
Jan 07, 2008 | JVC AV-27F702 27" TV
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
Haier HTF24R21 24" TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
