Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a 52 in. Rca television that I bought in 2003. When I turn it on it makes a high pitch sound and turns off in like 3 seconds with no picture and no sound.
  • chefsnow1 Oct 09, 2010
    Hi, I do not have any electrical expertise or anything. I dont have any schematics. I don't know if it is any different, but my tv is an Rca 52in.w15. When I hit the power button the green light will come on with a high pitch sound and the green light will come in and go out about three times with no picture or sound. What should I do from this point?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. High pitch sound is caused due to power supply. You'll need to open the back of the unit and check/test HOT (horizontal output transformer) and flyback, replace the part that has gone bad however, replacing both the parts at the same time is recommended. Also check the power supply board for any bad components. This is only recommended if you have electrical expertise.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
  • Rylee Smith
    Rylee Smith Oct 09, 2010
    mso-bidi-font-family:"Times New Roman";mso-ansi-language:EN-US;mso-fareast-language:
    EN-US;mso-bidi-language:AR-SA">3 blink indicates on the Deflection board there are 3 capacitors CP
    114, 120 and 150. If any of them is puffed up on top replace all the 3
    capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold
    writing on them. Resolder all pins on Fly Back Transformer (FBT) also. If you dont have electrical expertise then it is always recommended to get this done by a professional.
    Please accept
    Thanks
    Rylee
    Thanks
    Rylee
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
My tv makes 3 even high pitched squeals when i turn it on. about 1 second each, then powers off. No picture no sound. All imputs. What do you have for suggestions on what it could be.
One of most two common reason why your set will not come on, is because it has lost the high voltage, the first thing to check is your horizontal output transistor, to see if it is shorted, it will be located bay the flyback, mounted on a metal heat sink. That is what is causing a squealing noise.
Oct 16, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74
the 3 blinks is definately meaning the flyback is defective. You need to replace the flyback its number 259296 you can get a replacement flyback at the following link with free installation instructions with step by step pictures of the repair. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | RCA P52937 52" Rear Projection Television
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Jan 26, 2008 | RCA P52830BL 52" Rear Projection...
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
