Not fully charging.. always on 68% maximum full charge.
  • 32,281 Answers
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Posted on Oct 07, 2010
Should my jvc videomovie gr-ax7 work on a half charged battery or do the battery's have to be charged up to there maximum?
I have always understood that it is 'best practice' to fully charge the batteries for electronic equipment. If they are continually only half charged, they can develop a 'memory' and no longer take a full charge.
The other criterion, of course, is that a fully-charged battery will last longer in use, and not let you down at a crucial point when filming.
May 19, 2016 | JVC Video Cameras
How do i get my garmin to charge to a full charge
You can connect to your computer with a usb cable until it is fully charged. And remember to turn it off after use each time in car. And actually, if you use it in your car and is always connect with the 12V DC, it is really not a matter it is fully charge or not. It still functioning well.
Mar 02, 2015 | Garmin nuvi GPS
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
Acer netbook battery cannot reach 100% charge?
As rechargeable batteries age they build up what is called a 'memory' or a 'charge memory'....
Let me explain how this works...you have a new battery and you run your laptop normally until it hits 15% charge then you charge it up and use it again until about 15% then charge it again....with the charge only dropping to 15% the battery builds up a 'memory' of that over a period of time (usually over at least a year up to a couple years) and then your battery's maximum capacity is no longer 100%. Same thing happens if you dont charge it fully each time, after a while it becomes incapable of taking a full charge.
What you can do to stop that in the future....when you get a new battery every now and then run its charge down to 1% then charge it to maximum. By doing that on a regular basis you help make sure the battery remembers its full charge capacity.
Feb 19, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
I have ER224 RC hair trimmer, I have been charging this for 2 days, it's led is still RED, i dont know if it is fully charged yet or not? is the led green for fully?
some devices doesn't have indicator that it is already fully charged so my advise is since almost all rechargeable gadgets needs to be charged 4-8 hours depending on the power needed by the device for example a cellphone that uses 37 volts li-ion battery should be charged 3-4 hours to use it in its maximum capacity. so look how much power needed by the device and charge it at least 4 hours for the battery to be full.
Dec 17, 2010 | Panasonic ER224
I have an htc ozone, what is the proper way to charge it for maximum battery life? seems to drain out shortly after an all night full charge. Thanks.
I just got my Ozone a few days ago. What you should always do with an electronic device is charge it fully before turning it on. Then using it until it dies completely with no battery. Then fully charge it again for maximum battery life.
You can go to Start, Settings, More, Power, Power Management. Change the different things to make it save on power. Also a big help is Start, System tools, Task Manager and delete everything that is being used. That just turns it off in the background, it doesn't delete the program.
Aug 31, 2009 | HTC Touch P3450 Smartphone
Tungsten 2E battery will not fully charge.
Your E2 is showing a battery that is just about dead. Luckily you can replace it
Aug 06, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Nov 15, 2008 | Garmin StreetPilot c550 GPS Receiver
Battery charge question
in this phone when the battery is fully charged the running battery indicators stop at full position. U must charge every phones battery a maximum of 2 hours b'coz charging more than it reduces battery life and if the battery is not fully charged in 2 hours u must charge it after 20 minutes again
May 20, 2008 | Nokia 2610 Cellular Phone
Battery Problem
take out the battery, let set for a few min. and put it back in, try it. If does not work you need a new battery
Nov 26, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
