Question about Sony Televison & Video
On start up TV goes into green blinking standby for approximately 1min, then switches to 5 red blinks continuously, without video or audio. The service manual indicates a ballast problem. I checked the lamp and can visualize that it is broken. My question is could a defective ballast have caused the lamp to pop or do I just need to replace the lamp?
  • marcwinn Oct 07, 2010
    palaboy,
    I will replace both the Lamp and the Driver/ ballast. I would think that if the supply voltage to the Driver was incorrect that it would screw it up. Do you need to remove the fan to check the supply voltage or if the out voltage is correct the supply must be correct too?
  • marcwinn Oct 08, 2010
    I ordered a lamp and ballast from Discount Merchants which could take up to 7 days to arrive. The expert support helped clarify that my approach to my problem was correct.
  • Sony Master
  • 5,807 Answers
Thanks in advance for choosing Fixya for assistance.
it would be best to replace both, but try on your lamp first
For a thorough troubleshooting and
If you feel you can DIY , Check the voltages on all terminal of the ballast,
( start with the low voltage, not the high ones )
confirm voltages on the service manual for more accurate conclusion.
These will lead you to a board , which have transistors in detection circuits
Do not do these if you feel you cannot have someone to help you
( voltage measurement and transistor functions )
Posted on Oct 07, 2010
  • 3 more comments
  • Rommel Cana
    Rommel Cana Oct 07, 2010
    you do not need to remove the fans , it will or might give the desired voltage level on some points
    at a different voltage.
    However , if your trying to clean the fans , go.
    have you tried measuring voltages on the connector side only ( low voltage , not the supply voltage)
    there is also some kind of "tick " or something that you can here ( something that ignites )
    when these set is turn "ON " ( ballast board ) have a look but dont touch it ( HV ) even with
    the multimeter ( and also a good sense of hearing is required )
    If it does, it just proves your ballast is good
  • Rommel Cana
    Errata:
    there is also some kind of "tick " or something that you can " here "
    " here " should be hear
  • Rommel Cana
    Errata: there is also some kind of "tick " or something that you can " here "
  • Rommel Cana
    there is also a thermal sensor ( different on each model ) check on the connectors as well
    for possible loose on the connector
    the low voltage I am referring to are from the HV detection circuits it have only 5V and no
    more than 5.5V , check on it
    I hope you will make it work again
  • Rommel Cana
    check on the connectors as well for possible loose on the connector
    it have only 5V and no more than 5.5V ,
    check on it
TROUBLE SHOOT LC-60E78UN TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 30, 2016 | Sharp Televison & Video
No power on (LCD27TV006HD)
Does the standby light continue to blink? IF so, count the number of blinks and go to:
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
That may help you decide what is going on.
In the long run you will probably need to have a tech take a look at it. The problem you describe is usually a serious matter that needs repair by a trained technician..
Goodluck,
Don't forget to rate me as fixya...
Feb 03, 2008 | Televison & Video
Tv shut itself off and will start to power up normally but then goes to stand by the red standby and both green lights start to flsah
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 02, 2016 | Televison & Video
HL-T6176S red and green flashing
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Nov 27, 2017 | Televison & Video
KDF-60XBR950 Red light blinks 5 times
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Standby light flashes green and red, the pattern is 11 flashes, is this serious
Submit the TV to an authorised SONY workshop for a quote and a full assessment of the actual problems. This repair could prove expensive/uneconomical, but it is up to you. The quote (and their second opinion) should help.
Here is a list of the problems that might have occurred indicated by the number of blinks:
* Unit is dead, No blinks = Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
* Continuous blink once a second, no pausing = No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
* 1 blink = not used for the self-diagnosis
* 2 blinks = B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
* 3 blinks = B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
* 4 blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
* 5 blinks = AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
* 6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
* 7 blinks = High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
* 8 blinks = Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
* 9 blinks = Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
* 10 blinks = Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
I assume the TV has no picture/sound as a result.
Dec 15, 2010 | Sony KV-36FS12 36" TV
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
No picture and no sound
Mar 11, 2017 | Samsung Televison & Video
Televison & Video Logo
256 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
