Question about Gateway FPD2275W LCD Monitor
I placed my computer in sleep mode. When i tried to turn it back on the computer comes on, but my monitor has no response at all! no blinking lights or anything. It dees seem to be making a hight pitched noise though. Please Help!
  • 11,361 Answers
Look for bad caps as shown:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 07, 2010
LCD AOC 2436Swa is stuck on active-off mode
tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
Jan 08, 2013 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
I unplugged my computer and turned off the monitor to save power since we were not using. Now with the computer plugged in, when I turn monitor on the green light just blinks.
Make sure the data plug is in correctly. Turn the computer on. No you can try using the power button on the monitor to power it off and on. Or you may need to pull the power for the monitor out of the plug and then put it back in.
The blinking light means the monitor is in sleep mode. They need activity on the data or signal cable before they wake up. Unfortunately sometimes they get stuck and you have to reboot them to wake them up. I have seen a few where they had failed and would not come out of sleep mode but that is pretty rare. Usually you just have to sweet talk it and threaten it a bit and pull it plug a few times and all of a sudden it will start up,
Feb 01, 2011 | Hanns.G Corporation HW173D Monitor
Our Flat screen monitor comes on for a few moments and turns right back off any idea why it can be doing that?
it turns on as a "self-check" but if it doesn't get a correct input signal it goes to sleep.
Or you might have it going to sleep in settings.
Check to see if the power light stays on or blinks when it goes off. blinking means sleep mode
Apr 16, 2010 | Computers & Internet
Power on and monitor goes to sleep mode
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 19, 2010 | Acer AL2216W LCD Monitor
HP vs19e Computer turns on Monitor stays Black. blue light blinks
Same here- I understand that the capacitors are bad and need to be replaced. I am going to undertake it myself. Radio Shack sells them.
Apr 08, 2009 | HP vs19 19" LCD Monitor
Computer won't come out of sleep mode.
If you are running windows vista and it is actually asleep or hibernating,Ctrl + Alt + Del should do it.It's the only way,I have found other than turn the feature off.
Jan 09, 2009 | HP Pavilion Media Center a1330n - AMD...
Flat monitor is stuck in sleep mode
difficult to say what is sleep mode yellow light green ight blinking light pleas elaborate
May 10, 2008 | Computers & Internet
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Gateway FPD2275W LCD Monitor Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
