Question about Blueant Q1 Bluetooth Headset
I was updating the firmware...what is the approximate time it takes to upgrade...it seems to take a long time and I can't tell if my computer is hanging up or not...Right now my blueant is not turning on when I disconnect the device. I need help or suggestions?
  • 214 Answers
The updater should take a maximum of 10 minutes. If it froze something most likely intergerd with the updater, this could be the anti-virus/firewall of your computer or any other high bandwith program you have running. Also you have to have the device connected to a USB port connected directly to the motherboard. If this doesn't work I would simply try it on another 32 bit PC and it should work just fine.
Regards,
Rylan
Posted on Dec 15, 2010
Can i update camera firmware through a printer dock?
Kodak does not suggest a firmware upgrade through a printer dock. Instead, they recommend using an SD card (memory card).
First:
  1. Click Download, then save the firmware file to your computer desktop.
  2. Double-click the *.exe file. When the WinZip Self-Extractor screen appears, select a folder or accept the default location, then click Unzip. The firmware file unzips to the specified folder.
  3. Note the location of the *.FW file, then close the WinZip Self-Extractor.
Instructions:
  1. If you have pictures/videos on your camera's internal memory or on the memory card, save them to your computer.
  2. Ensure that your camera batteries are fully charged.
  3. Turn off your camera.
  4. Insert the memory card into your computer or into a card reader attached to your computer.
  5. Verify that the memory card has at least 100 MB free space.
  6. On your computer, select the removable drive associated with the memory card or card reader.
  7. If a System folder does not exist on the memory card, create one. From the removable drive window, select File > New > New Folder, then name the new folder System.
  8. Copy the *.FW file from your computer into the System folder.
  9. Remove the memory card from your computer or card reader, then insert it into your camera.
  10. Turn on your camera, then follow the instructions to begin the firmware upgrade. The upgrade takes approximately two minutes to complete.
  11. When "Upgrade was successful" appears on the LCD, select Delete Upgrade File to delete the firmware file from the memory card.
  12. Turn off your camera, then turn the camera on to activate the new firmware.
Feb 07, 2014 | Kodak EasyShare P880 Digital Camera
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
My C 743 does not see the SD card.The card is good and is used in another C 743. Have I messed up a menu setting or is this a camera problem?
the kodak C743 can only take upto 8gb SDHC card , if you have a 16 / 32 / 64 & 128gb card these will not work
try upgrading the firmware from the website by this method
  1. Visit the EASYSHARE Software page and download the latest version of software.
  2. Connect the camera to your computer using a USB cable.
    NOTE: The first time you connect your camera to your computer, Sync and Transfer Setup or Sync and Transfer Assistant prompts appear on the screen. Follow the prompts to set up the camera as a device in the software.
  3. Remove the memory card from the camera.
  4. Turn on the camera.
  5. Start EASYSHARE Software.
  6. Select Tools > Sync and Transfer Manager.
  7. Select your device from the list in the left column, and then select the Info tab.
  8. Click Update Firmware, and go to the location where you downloaded the firmware file.
  9. Click Open to copy the file from your computer to the internal memory on the camera.
  10. Turn off the camera, and then disconnect the USB cable from the camera.
  11. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  12. Turn off the camera, and then turn it back on again.
good luck
Apr 01, 2011 | Kodak Cameras
Missing latest firmware update file .bin
Updating your Routers Firmware
Locate and download the firmware file from the Belkin support site. (Type in your part number in the search box in the top right and look for "Firmware" in the title)
Save the file to a location on your computer where you can get to it easily, such as your desktop.
Connect the computer to one of the four gray ports on the back of the router.
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
Click the Browse button toward the middle of the screen to search for the file you saved previously.
Select the firmware file by left-clicking on it and then click the Open button in the lower right corner of the window. This will take you back into the router's interface.
Click the Update button.
A prompt asking, "Are you sure you want to continue with upgrading?" will appear. Click OK.
A second prompt will open telling you the router will not respond during the upgrade and warning you not to remove the power supply to the router. Click OK once more.
Congratulations. The firmware has been updated successfully
Oct 15, 2010 | Belkin (F5D7231-4) Wireless Router
Lately, the past two days or so, my router speeds has dropped completely (20kb dl speed). I know why, I need to update firmware, but how??
Upgrading the router's firmware
  • Locate and download the firmware file from the Belkin support site.
  • Save the file to a location on your computer where you can get to it easily, such as your desktop.
  • Connect the computer to one of the four LAN ports on the router.
  • Open a web browser on the computer.
  • In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard. Note: Some routers use 192.168.1.1 or 192.168.0.1.
  • Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  • Click on "Firmware Update" toward the bottom of the left-hand menu.
  • Click the Browse button toward the middle of the screen to search for the file you saved previously.
  • Select the firmware file by left-clicking on it and then click the Open button in the lower right corner of the window. This will take you back into the router's interface.
  • Click the Update button.
  • A prompt asking, "Are you sure you want to continue with upgrading?" will appear. Click OK.
  • A second prompt will open telling you the router will not respond during the upgrade and warning you not to remove the power supply to the router.
  • Click OK once more.
  • Congratulations. The firmware has been updated successfully.
Nov 12, 2009 | Belkin (F5D7230-4) Router (587009)
Dissconnets
If that is the problem, before do the update of the firmware try first to reset the router so it will be back to its default settings and then after that continue with the firmware upgrade.......
Oct 18, 2009 | Arris BR700 Router
Kodak easy share C813, the display is over saturated
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
OR
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at www.kodak.com/go/easysharesw, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Sep 10, 2009 | Kodak Easyshare C813 Digital Camera
Firmware upgrade not working
Are you absolutely sure that you loaded the firmware for your correct model #? Try downloading the auto-updater software and see if it will take the upgrade on the next go around.
If not, that player is fried - update during firmware upgrade is no good. Call rCA to see if you are still in warranty.
Usually the "50MB of space needed to operate error" is easy to fix, but also most other manufacturers have a specific FAQ on their website that tells you how to fix it. RCA did not have anything like that for this model. also, most other manf. have a recovery tool of some kind - absent on this model.
Jun 28, 2008 | RCA OPAL M4001 MP3 Player
My mp3 player
Re-run the installation CD, this will enable you to "repair" the installation by adding the missing files. The first time you connect the player, it may say "connecting" for a while, but 30 minutes, for instance, isn't normal.
Go ahead and do a firmware upgrade as well:
Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Jan 12, 2008 | SanDisk Sansa E280 MP3 Player
Player spontaneously shuts off (battery is charged!)
Hi. I recommend a firmware upgrade. You can obtain this by doing the following: 1) Connect the player to your computer with the USB cable. 2) Wait for "idle" to be displayed on the player screen. 3) Double-click the file that you downloaded from the Rio website. The update should take approximately 30 seconds to load. and here is the link for your firmware upgrade file. http://www.digitalnetworksna.com/support/rio/downloads/ce2100/RioCe2100_firmware_143.exe Good Luck
Jun 16, 2007 | Rio CE2100 MP3 Player
Blueant Q1 Bluetooth Headset Logo
130 people viewed this question
Top Blueant Radio Communications Experts
Josh Whitehead
Josh Whitehead
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
